Monitor Attacks
The Attacks page includes details of all the open and closed attacks on the managed applications. By default, this page displays an overview of the selected application. See Monitor Application Security Using Secure Application.
Attacks
The Attacks page displays these details:
| Field Name | Description |
| Attacks By Outcome |
This provides information on these state of the attack:
| Top Applications |
This chart displays the top 10 applications based on open attacks per application. If you select a specific application scope, then only that application is displayed. To view all the applications, reset the application scope. See Monitor Application Security Using Secure Application. These applications are in either an exploited, blocked, attempted, or state versus the total number of open attacks on the application. Hover over each state to view the number of blocked, exploited, and open attacks. |
| Top Attack Types |
This chart displays the top 10 attack events that are in an exploited,blocked, or attempted state versus the total number of open attacks on the events. Hover on each state to view the number of blocked, exploited, attempted, and open attacks. Attack Types include:
| ID |
The ID of the corresponding Attack. Secure Application generates this ID. You can modify this ID on the attacks details page. To view the attack details page, click the desired row. Click this field to sort the ID numerically. |
| Outcome |
Click this field to sort the values alphabetically. |
| Attack Type (Events) | The type of the attack and count of that attack type. |
| Event Trigger | Relevant information from the runtime behavior resulting from the event where Secure Application determined a potential attack. |
| Application |
The application affected by the attack. |
| Business Transaction |
When you click an Attack ID, you receive a summary for each Attack, and a Business Transition type, if you have a Business Transaction enabled. See Monitor Business Transactions. |
| Tier |
The tier name and the number of nodes. You can click |
| Last Detected |
The time that is elapsed since the last event within the attack. Click this field to sort the values in ascending or descending order. |
| Status |
The status of the attack is defined as either open or closed. If you have Configure permissions, click the checkboxes for the required rows and then click the Set Status option to set the appropriate status. Click this field to sort based on the Open or Closed state. |
View Attack Details
The Attack details page provides information of the attack. The top pane provides a summary of the attack. To view the application flow map, you can click the flow map icon () next to the application name. The bottom pane is split into left pane (a list of events correlated to the attack automatically) and right pane (the details of a selected event).
You can use the Search filter to filter by: Outcome, Event Type, Attack Type, or Affected Tiers.
| Outcome | The outcome of the event. This provides information on whether the selected event is Exploited, Blocked, or Attempted. |
| Event Type | The type of the attack event or the vulnerability name. |
| Attack Type | The type of the attack such as RCE and so on. |
| Application | The affected application. |
| Tier | The affected tier. |
| Timestamp | The time the event is detected. |
| Timestamp | The date and time when the event is detected. |
| Affected Node |
The name of the affected node. You can click the flow map icon ( |
| Event Trigger | It displays the attack target. It can be a file, host, command, etc. |
| Vulnerabilities |
The type of vulnerability used for the attack. Based on the event type, this field may not be displayed. If the value is displayed, click the value to view the vulnerability details. For information about Vulnerabilities, see Monitor Vulnerabilities. |
| Entry Point | The webserver URL accessed by the client in the transaction that triggered the event. Based on the event type, this field may not be displayed. |
| Client IP |
The IP address of the remote endpoint of the connection in the transaction. This IP address can be the IP address of client machine, load balancer or proxy in a client network. |
| Network Flow | The network flow as observed from the node that includes the source and the destination IP address. |
| Details |
The details about the resulting behavior of the node triggered by an inbound request. The details may change based on the event and attack type. Click Show More to view the Details dialog box. You can copy the details as per your requirement. |
| Stack Trace |
Details of the stack trace for the corresponding event. Click Show More to view the Stack Trace dialog box. You can use this information to guide developers to the lines of code that were used to achieve the result of the event. You can copy the details as per your requirement. |
| Socket Address |
The destination IP address. It can be a host, network, subnetwork, etc. |
| Policy |
The action that is used for this event based on the existing policy when the event is detected. If you have the Configure permission, you can change the policy by clicking this value. See Secure Application Policies. |
