Edge Processor metrics reference
As an Edge Processor administrator, you can create dashboards to monitor the health, status, and information of the data that is flowing through your Edge Processors. You can do this from your Splunk platform deployment. For more information on creating dashboards, see About dashboards.
You can create these queries by using the Search & Reporting app in the Splunk platform. Aside from searching and creating dashboards to monitor your Edge Processor, you can configure alerts to notify specific changes that you would like to track. For more information on how to configure alerts in the Splunk platform, see Getting started with alerts.
Searching for Edge Processor metrics
The Edge Processor metrics are stored in the _metrics index. To access these metrics, use the mstats command. The following table contains the common query patterns used to search for these metrics.
Stats metric term When to use
Rate_sum()
Counters
Latest()
Gauges
Avg()
Averages over time
Perc95()
Latency percentiles
An example query syntax would look like the following:
mstats rate_sum(metric_name) WHERE index=_metrics span=1m
To see more information on Edge Processor example searches for common metrics, see Example searches for Edge Processor metrics.
Data processing metrics
Throughput metrics
Use these metrics to track how data moves from ingestion to destination.
Track the rate at which data is successfully processed through the Edge Processor instance over a specific period. The following table lists the metrics that track this information.
Metric Metric name Unit Label
Data received by processor processor_bytes_in_total Bytes dataset_name, evt_source_type, signal_type
Data sent by processor processor_bytes_out_total Bytes dataset_name, evt_source_type, signal_type
Events received processor_events_in_total Event count dataset_name, evt_source_type
Events sent processor_events_out_total Event count dataset_name, evt_source_type
Egress data metrics
Track the rate at which outbound data is sent from the Edge Processor to an external destination over a specific period. The following table lists the metrics that track this information.
Bytes written to destination egress_bytes_written_total Bytes exporter_type, dataset_name, signal_type
Send attempts including retries write_to_sink_attempts_total Count exporter_type, dataset_name
Export errors export_destination_errors_total Count exporter_type, dataset_name, errorType
Write latency to destination write_to_sink_latency_seconds Histogram exporter_type, dataset_name, signal_type
Logs successfully sent exporter_sent_log_records Count exporter
Metrics successfully sent exporter_sent_metric_points Count exporter
Spans successfully sent exporter_sent_spans Count exporter
Failed log sends exporter_send_failed_log_records Count exporter
Failed metric sends exporter_send_failed_metric_points Count exporter
Failed span sends exporter_send_failed_spans Count exporter
Queue metrics
Track the data flowing through the queue and retries over a specific period. The following table lists the metrics that track this information.
Metric Metric name Unit Type
Current queue size (entries) queue_size_entries Count Gauge
Current queue size (bytes) queue_size_bytes Bytes Gauge
Maximum queue capacity queue_max_bytes Bytes Gauge
Undispatched entries queue_undispatched_entries Count Gauge
Bytes written into queue enqueued_entries Count Counter
System and host metrics
Process metrics
Use these metrics to track the health or performance of your host or machine.
Monitor the health of the process of your Edge Processor by using these metrics in your search. The following table lists the metrics that track this information.
Process uptime process_uptime Seconds -
Physical memory usage process_memory_rss Bytes -
Heap memory allocated process_runtime_heap_alloc_bytes Bytes -
CPU time used process_cpu_seconds Seconds state
Host metrics
Monitor the health of your host by using these metrics in your search. The following table lists the metrics that track this information.
CPU usage by state system.cpu.time, system.cpu.utilization Seconds, ratio CPU, state
RAM usage by state system.memory.usage, system.memory.utilization Bytes, ratio state
Disk I/O operations and throughput system.disk.io, system.disk.operations Bytes, count device, direction
File system capacity and usage system.filesystem.usage, system.filesystem.utilization Bytes, ratio device, mountpoint, type, state
Network traffic and errors system.network.io, system.network.errors, system.network.packets, Bytes, count device, direction
Metric label reference
Resource identification labels
The following tables contain corresponding labels for specific metrics.
Metric attribute Label Example
Unique supervisor instance ID service_instance_id sup-abc123
Supervisor group ID processor_id group-1
Tenant ID tenant tenant-xyz
Machine host name host_name edge-host-01
Pipeline and component labels
Pipeline ID pipeline_id 7200faed6f099ed392c155e339e5ddea_1777916602202068260_rjlqv
Exporter component ID exporter S2S/shared.pipelines.default_splunk_cloud_destination
Type of exporter exporter_type awss3, splunkhec, splunk
Receiver component ID receiver “*hecreceiver”
Transport protocol transport http
Data classification labels
Telemetry type signal_type logs, metrics
Dataset name dataset_name shared.pipelines.default_splunk_cloud_destination
Dataset kind dataset_kind hecreceiver
Source type evt_source_type access_combined
Agent hostname agent agent-host-01
Internal index flag internal True, False
Error category error_type Unclassified, DestinationError, ConnectionForbidden, HostNotFound, InvalidRequest. ResourceNotFound,
The following table highlights the searches that you can use to create dashboards for Edge Processor metrics. For more information on how to create dashboards to monitor your Edge Processor health, see About dashboards.
Metrics Example search
Edge Processor data throughput overview | mstats sum(processor_bytes_in_total) as bytes_in sum(processor_bytes_out_total) as bytes_out sum(egress_bytes_written_total) as bytes_egress WHERE index=_metrics span=5m | eval in_mb = round(bytes_in / 1024 / 1024, 2) | eval out_mb = round(bytes_out / 1024 / 1024, 2) | eval egress_mb = round(bytes_egress / 1024 / 1024, 2) | timechart span=5m avg(in_mb) as "Processor Input (MB)" avg(out_mb) as "Processor Output (MB)" avg(egress_mb) as "Egress (MB)"
Edge Processor queue health | mstats latest(queue_size_bytes) as queue_bytes latest(queue_max_bytes) as queue_capacity WHERE index=_metrics by host_name span=1m | eval queue_usage=round(queue_bytes/queue_capacity*100, 2) | timechart max(queue_usage) as queue_usage by host_name useother=f usenull=f
Edge Processor processing latency | mstats latest(queue_size_bytes) as queue_size latest(queue_max_bytes) as queue_capacity WHERE index=_metrics BY exporter span=1m | eval utilization_pct = round((queue_size / queue_capacity) * 100, 2) | timechart span=1m avg(utilization_pct) by exporter
Edge Processor resource utilization | mstats latest(process_memory_rss) as memory latest(process_runtime_heap_alloc_bytes) as heap WHERE index=_metrics BY service_instance_id span=1m | eval memory_mb = round(memory / 1024 / 1024, 2) | eval heap_mb = round(heap / 1024 / 1024, 2) | timechart span=1m avg(memory_mb) as "RSS Memory (MB)" avg(heap_mb) as "Heap Memory (MB)"
Top datasets by volume in Edge Processor | mstats sum(processor_bytes_in_total) as bytes WHERE index=_metrics BY dataset_name span=1h | eval gb = round(bytes / 1024 / 1024 / 1024, 3) | stats sum(gb) as total_gb by dataset_name | sort -total_gb | head 10
Edge Processor exporter comparison | mstats sum(egress_bytes_written_total) as bytes perc95(write_to_sink_latency_seconds) as latency sum(exporter_errors_total) as errors WHERE index=_metrics BY exporter_type span=5m | eval gb = round(bytes / 1024 / 1024 / 1024, 3) | stats avg(gb) as avg_gb avg(latency) as avg_latency_sec sum(errors) as total_errors by exporter_type
Edge Processor agent ingestion breakdown | mstats sum(processor_bytes_in_by_agent_total) as bytes WHERE index=_metrics BY agent span=1h | eval gb = round(bytes / 1024 / 1024 / 1024, 3) | stats sum(gb) as total_gb by agent | sort -total_gb
