Use templates to create pipelines for Edge Processors
To help you get started on creating and using pipelines, the Edge Processor solution includes sample pipelines called templates. Templates are prebuilt pipelines that are designed to work with specific data sources and use cases.
Templates include sample data and complete SPL2 configurations, so you can use them as a starting point in order to build custom pipelines to solve specific use cases or as a reference to learn how to write SPL2 to build pipelines. For a list of available templates, see SPL2 pipeline templates reference.
In addition to the templates that are available by default, you can also work with custom templates that are provided by SPL2-based apps. If an app that contains templates is installed on the Splunk Cloud Platform deployment that is pair-connected with your tenant, those templates become available in the Edge Processor service and are listed alongside the default templates. For information about how to create custom templates in apps, see Create custom pipeline templates in the Splunk Developer Guide.
To view a list of the available pipeline templates, log in to your tenant, navigate to the Pipelines page, and then select Templates.
To create a pipeline using a template, complete the following steps.
Before starting to create a pipeline, make sure that the destination that you want the pipeline to send data to is listed on the Destinations page of your tenant. If your destination is not listed on that page, then you must add that destination to your tenant. See Add or manage destinations for more information.
Steps
  1. Navigate to the Pipelines page and then select New pipeline.
  2. Select the pipeline template that you want to use, and then select Next.
  3. Specify a subset of the data received by the Edge Processor for this pipeline to process. To do this, you must define a partition by completing these steps:
    1. Select the plus icon (This image shows an icon of a plus sign.) next to Partition or select the option that matches how you would like to create your partition in the Suggestions section.
    2. In the Field field, specify the event field that you want the partitioning condition to be based on.
    3. To specify whether the pipeline includes or excludes the data that meets the criteria, select Include or Exclude.
    4. In the Operator field, select an operator for the partitioning condition.
    5. In the Value field, enter the value that your partition should filter by to create the subset. Then select Apply. You can create more conditions for a partition in a pipeline by selecting the plus icon (This image shows an icon of a plus sign.).
    6. Once you have defined your partition, select Next.
  4. Templates include sample data, so you can review it and then select Next.
  5. Select the name of the destination that you want to send data to. If your template contains multiple data destinations, perform the steps to select each data destination.
  6. (Optional) If you selected a Splunk platform S2S or Splunk platform HEC destination, you can configure index routing:
    1. Select one of the following options in the expanded destinations panel:
      Option Description
      Default The pipeline does not route events to a specific index.
      If the event metadata already specifies an index, then the event is sent to that index. Otherwise, the event is sent to the default index of the Splunk platform deployment.
      Specify index for events with no index The pipeline only routes events to your specified index if the event metadata did not already specify an index.
      Specify index for all events The pipeline routes all events to your specified index.
    2. If you selected Specify index for events with no index or Specify index for all events, then in the Index name field, select or enter the name of the index that you want to send your data to.
    Note: Be aware that the destination index is determined by a precedence order of configurations. See How does an Edge Processor know which index to send data to? for more information.
  7. Select Done to confirm the data destination.
  8. To save this template as a pipeline that you can apply to Edge Processors, do the following:
    1. Select Save pipeline.
    2. In the Name field, enter a descriptive name for your pipeline.
    3. Select Save.
  9. To apply this pipeline to an Edge Processor, do the following:
    1. Navigate to the Pipelines page.
    2. In the row that lists your pipeline, select the Actions icon (Image of the Actions icon) and then select Apply/remove.
    3. Select the Edge Processors that you want to apply the pipeline to, and then select Save.
    Note: You can only apply pipelines to Edge Processors that are in the Healthy status.
It can take a few minutes for the Edge Processor service to finish applying your pipeline to an Edge Processor. During this time, all Edge Processors that the pipeline is applied to enter the Pending status. To confirm that the process completed successfully, do the following:
  • Navigate to the Edge Processors page. Then, verify that the Instance health column for the affected Edge Processors shows that all instances are back in the Healthy status.
  • Navigate to the Pipelines page. Then, verify that the Status column for the pipeline contains a The pipeline is applied icon (Image of the "applied pipeline" icon).
Note: You might need to refresh your browser to see the latest updates.
The Edge Processor that you applied this pipeline to can now process the data it receives based on the processing instructions defined in the template.
