Dead Man’s Snitch integration for Splunk On-Call
The Dead Man’s Snitch integration allows your snitches to automatically trigger incidents within Splunk On-Call.
Enable the integration
  1. In Splunk On-Call, select Integrations then Dean Man’s Snitch.
  2. Select Enable to generate your endpoint destination URL.
  3. Copy the Service API endpoint to your clipboard.
In Dead Man’s Snitch
In Dead Man’s Snitch, navigate to the integrations page and select to add VictorOps.
Paste the copied REST Endpoint into the Integration URL. Replace $routing_key with the desired routing key, then save. For example, assuming a $routing_key value of "database":
………36437/$routing_key ==> ……..36437/database
You’ll be redirected back to the integrations page where your routing key appears as a configured integration. Snitches will now automatically trigger incidents within On-Call. Test the integration with fake incidents to make sure it works.
