Manage Modern Automation Broker Groups
View, edit, and delete Automation Broker Groups
View a Modern Automation Broker Group
Within Splunk SOAR, from the Home menu, select Administration, then Product Settings, then Automation Broker.
Select the Modern Automation Brokers tab, then select the Groups tab.
View information about each configured group. For details on Status, see the separate section later in this article.
At this point, you can choose different actions.
Edit a Modern Automation Broker Group
From the Actions menu, represented by three dots, select Edit Group.
Make modifications to any or all of the parts of the group: the group name, its apps and assets, its modern Automation Brokers.
Select the external link icon next to the apps and assets selectors to open a new instance of Splunk SOAR in a separate browser window, so you can work with your system's apps and assets.
Select Save to save your changes.
Delete a Modern Automation Broker Group
From the Actions menu, represented by three dots, select Delete group.
Specify the option you want to use when you delete this group:
Note: If there are assets associated with the group, a warning displays. If you delete the group, using either option listed here, the asset association will break, which might disrupt playbook runs. Assets must be associated with Automation Brokers in order to function in playbook runs.-
Delete group only Deletes only the grouping of brokers, apps, and assets. Brokers in the group remain as single, standalone brokers; if they are parts of other broker groups, they remain in those groups.
Delete group and its brokers Deletes the group itself along with any brokers contained in this group, even if those brokers are part of other broker groups.
Select Delete to proceed with the delete action.
