Configure Connectors to use the Classic Splunk SOAR Automation Broker
You must configure connectors before the Classic Splunk SOAR Automation Broker can connect to your assets to perform actions.
Set up a Connector to use the Splunk SOAR Automation Broker
You must configure a connector to use a Splunk SOAR Automation Broker.
Note:
You cannot mix Modern and Classic Automation Brokers within the same asset. For details on Classic Automation Brokers, see Configure Connectors to use the Classic Splunk SOAR Automation Broker.
For details on asset configuration, see Add and configure apps and assets to provide actions in Splunk SOAR (Cloud) or Add and configure apps and assets to provide actions in Splunk SOAR (On-premises) .
  1. In Splunk SOAR (Cloud) or Splunk SOAR (On-premises), select Home then Apps.
  2. Locate the connector that you want to configure.
    1. To edit a configured asset, select the arrow symbol ( ▶ ) labeled configured assets, then select the entry for the asset you want to edit.
    2. If you want to create a new asset for the connector, select the Configure New Asset button.
  3. Select the Asset Info tab.
  4. In the Automation Broker drop-down menu, select the name of the Splunk SOAR Automation Broker you want the connector to use.
  5. Select Save.
Set up environment variables to apply to your connector configurations
You can set up variables for your connector configurations in Splunk SOAR (Cloud) or Splunk SOAR (On-premises) deployment. These variables are applied on an individual connector's settings.
Set environment variables for a specific connector configuration
You can set up environment variables for a specific connector configuration. For example, add connector-specific proxy settings, or to create multiple connector configurations for multiple sites and Splunk SOAR Automation Broker instances.
  2. Locate the connector that you want to set up environment variables for.
  3. Follow the steps to create or modify a connector configuration. See Set up a Connector to use the Splunk SOAR Automation Broker.
  4. While editing the connector configuration, select the Asset Settings tab.
  5. Select Advanced.
  6. Select + Variable and add a new environment variable. If the variable is a password, certificate, or other secret, select the Secret checkbox.
  7. Select Save.
For example, if you have four different sites with different firewall configurations, install a Splunk SOAR Automation Broker at each site and set up four different connector configurations for the firewall connector, each one specifying different environment variables specific to the site settings.
