Naming conventions for topics and sections
Ensure topic and section names are clear and descriptive to help users understand the content and locate information efficiently.
Succinct and descriptive names for topics and sections let a user know what they can expect to find in the content. Topic titles that include the product name tell readers which product they are in when they land on that topic from a search. Clear headings support every reader's ability to locate information on a page.
Best practices
Follow these best practices when creating titles and headings in your content:
- Use sentence-style capitalization for titles and headings. See Capitalization.
- Write titles and headings using words that are short, descriptive, and specific.
- When possible, lead with a keyword.
- Include the product name in the topic title. If the product name is very long, use an approved abbreviation. If you're not sure whether an abbreviation is approved for use, check with the Information Architecture team.
- You don't need to repeat the product name in every section heading on a page.
- Focus titles and headings around what a user can do with the product. Stay away from creating titles and headings that describe a feature.
- Remove vague terms or phrases in titles and headings, such as "Other", "Miscellaneous", "Introduction", or "Before you begin". Use definitive language instead.
- Don't use special formatting in headings, such as monospaced font or italics.
- Don't use numbers in headings to indicate a sequence unless you're listing parts of a tutorial. See Using numbers in text.
- You can write topic titles or section headings in the form of a question.
The order of headings
Use only 1 topic title per page.
Aim to use second-level subheadings as the deepest level in your topic.
Use third-level subheadings only if all of the content must be on the same page and can't be promoted to the second level.
If you need to nest content beyond the third level, create a separate topic and link to the new topic from the previous topic.
Moods and phrases for topics or section headings
As a guideline, use the following moods and phrases in your titles and headings for the type of content you're writing:
| Type of content | Mood or phrase to use |
| Task information | Imperative mood. Use command verbs in the present tense. | Configure correlation searches | Configuring correlation searches |
| Reference information | Noun phrase |
| Conceptual information | Gerund phrase or noun phrase |
| Scenario-based content | Third-person point of view. Use indicative verbs after a persona's name. |
Examples of topic titles and section headings
The following table shows examples of good topic titles and section headings:
| Original title | A clearer, more descriptive title |
| Import entities | Import entities into ITSI from a CSV file |
| Use setup pages | Enable first-run configuration with setup pages in Splunk Cloud Platform or Splunk Enterprise |
| About the Splunk App for CEF | How the Splunk App for CEF works |
| Configure inputs | Configure inputs for the Splunk Add-on for AWS |
Include a lead-in sentence after a title or heading
After every topic title or section heading, include a line of text that provides information that the reader needs to know. In most cases, don't follow a topic title or second-level heading with another heading, a list, a table, or an image.
There are times, however, when it's acceptable to follow a topic title with a second-level heading and have no intervening text, or to follow a second-level heading with another section heading and have no intervening text:
- In a reference topic, such as a glossary of terms or commands.
- In a task, when the text between the heading and the numbered task steps merely repeats the heading.
Naming your topic in a table of contents
In most cases, use the same title for both the topic title and the title that appears in the guide's table of contents (TOC).
Some Splunk docs authoring platforms let you use a different name in a TOC. If you need to abbreviate the topic title in the TOC, make sure it aligns closely with the topic title.
If the name in the TOC differs significantly from the topic title, readers aren't sure if they're in the right topic when they select one in the TOC.
Follow these guidelines when abbreviating your topic title in the TOC:
- Don't change the primary verb and object of the title.
- It's okay to remove the product name to shorten the topic title.
- Don't change the mood or phrasing of the topic title in the TOC. Mood and phrasing cue the reader into the type of content they're about to read.
For example, if the topic title is written in the imperative mood, don't rephrase the title as a noun phrase or gerund in the TOC.
| Topic title |
| Install the Browser RUM agent for Splunk RUM | Install the Browser RUM agent | Install the instrumentation |
| Configure the Splunk Browser RUM instrumentation | Configure the instrumentation | Configuring instrumentation |
| Manually instrument browser-based web applications | Manually instrument the application | Manual instrumentation |
Can I write a title or heading in the form of a question?
You can write topic titles or section headings in the form of a question, but use this format sparingly.
