Install
Option Description Required Note
--agent_version string Set the AgentVersion. No N/A
--analytics_event_endpoint string Set the AnalyticsEventEndpoint. No N/A
--application_name string Set the ApplicationName. No N/A
--autostart_agent Set the AutostartAgent. No The default value is true.
--backup_dir string The agent backup directory.
This is used for saving the current directory of the agent to preserve and use during rollback.
The default value is the parent directory of the Smart Agent. For example,
If Smart Agent path is /opt/appdynamics/smartagent, the backup_dir path will be /opt/appdynamics/smartagent/backup.
No N/A
--controller_account_access_key string Set the ControllerAccessKey. Yes N/A
--controller_account_name string Set the ControllerAccountName. Yes N/A
--controller_cert_file string Set the ControllerCertFile. No N/A
--controller_global_analytics_account_name string Set the ControllerGlobalAnalyticsAccountName. No N/A
--controller_host_name string Set the ControllerHostName. Yes If using proxy, set appropriate proxy values.
--controller_port string Set the ControllerPort. Yes If not using proxy and enable_ssl is set to true, set controller_port=443. If using proxy, set appropriate proxy values.
--dotnet_compatibility_mode string Set the DotnetCompatibilityMode. No N/A
--download_protocol string Set the DownloadProtocol. No The default value is appd.
--download_uri string Set the DownloadURI. No The default value is https://download-files.appdynamics.com.
--enable_analytics_agent string Set the EnableAnalyticsAgent. No N/A
--enable_orchestration string Set the EnableOrchestration. No The default value is false.
--enable_ssl Set the ControllerEnableSSL. No N/A
--group string Set the Group. No N/A
-h, --help help for machine No
--hostname string Set the Hostname. No N/A
--ini string config file No The default value is config.ini.
--install_agent_from string Set the InstallAgentFrom. No N/A
--java_system_properties string Set the Java system properties for the Machine Agent.
For example, to configure a proxy for connecting to the controller, use -Dappdynamics.http.proxyHost=10.0.4.2 -Dappdynamics.http.proxyPort=9090.
For example, to configure a proxy for connecting to the controller, use -Dappdynamics.http.proxyHost=10.0.4.2 -Dappdynamics.http.proxyPort=9090. Similarly, you can use other system properties such as, -Dappdynamics.http.proxyPasswordFile and -Dappdynamics.http.proxyUser.
Multiple properties can be specified in a single string, separated by spaces. Similarly, you can use other system properties such as, -Dappdynamics.http.proxyPasswordFile and -Dappdynamics.http.proxyUser.
No N/A
--keep_backup Set the KeepBackup. No N/A
--{os}_custom_agent_install_path string Set the AgentCustomInstallPath. No Recommended. The Supported os types are linux and windows. If no value is provided, agent will install under <smart-agent-home-dir>/../machine-agent.
--{os}_install_root string Set the AppDDefaultInstallRoot. No The Supported os types are linux and windows. For example, linux_install_root string.
--machine_hierarchy string Set the MachineHierarchy. No N/A
--node_name string Set the NodeName. No N/A
--sim_enabled string Set the SimEnabled. No The default value is false.
--start_as_process Set the StartAsProcessPtr. No N/A
--temp_dir string Set the temporary directory. The default value is the temporary directory of the operating system. For example, /tmp for linux operating system. This is used to perform the tasks such as downloading the agent, unzipping the artifacts, during the install process. This directory gets cleaned up after the execution of the task. No N/A
--tier_name string Set the TierName. No
--user string Set the User. No N/A
Uninstall
Yes N/A
-h, --help help for machine No N/A
No N/A
--temp_dir string Set the temporary directory. The default value is the temporary directory of the operating system. For example, /tmp for linux operating system. This is used to perform the tasks such as downloading the agent, unzipping the artifacts, during the install or upgrade process. This directory gets cleaned up after the execution of the task. No N/A
--tier_name string Set the TierName. No N/A
Upgrade
--backup_dir string Set the AgentBackupDir. Yes N/A
--ini string config file No default "config.ini"
No N/A
--preserve_config Preserve the agent configuration. No The default value is true. If you want to customize the agent configuration in Controller, set the value to false.
