Cisco AppDynamics Distribution for OpenTelemetry Collector
- Go to Downloads and search for
Collector for OpenTelemetry. - Based on your environment, download any of the following Splunk AppDynamics Distribution for OpenTelemetry Collector >= 22.8.0.
- OpenTelemetry Collector Linux ARM64
- OpenTelemetry Collector Darwin ARM64
- OpenTelemetry Collector Windows AMD64
- OpenTelemetry Collector Linux AMD64
- OpenTelemetry Collector Darwin AMD64
- In the Controller top navigation panel, click OTel > Get Started.
- Click Generate Access Key.If you have already completed onboarding, you can retrieve the API Key in the Controller:
- In the top navigation panel, click OTel.
- Under the Access Key section, click Show.
- Copy the key to use in the Configure Exporters section below.
