TCP Connection Metrics in Metric Browser
- TCP flow setup/teardown times and errors
- Distribution of TCP flows for an element by throughput, setup time, lifetime, and round-trip time
- Flows closed by TCP resets
- Distribution of flows based on TCP configuration options (Selective Acknowledgement, Timestamp)
- For these metrics, the Metric Browser uses the terms Connection and Flow interchangeably. See Flows, Links, and Connections.
- Network Agents do not collect metrics for individual Connections by default. The recommended workflow is to enable TCP Flow metric collection only when you need to diagnose a performance issue on an associated node or Connection. See Dynamic Monitoring Mode and Network Visibility.
Viewing TCP Flow Metrics
To view advanced network metrics, open the Metric Browser and navigate to Application Infrastructure Performance. The Metric Browser shows connection/flow metrics for the following aggregations (highlighted in red):
- Application Infrastructure Performance >
- Advanced Network >
- Flows >
- All Connections/Flows for Application
- Flows >
- tier-name
- Flows >
- Call from<tier>to<service>
- Call from<node>to<node-or-service>
- Individual Connection/Flow(<node> to <service>)
- All Connections/Flows for Network Link(<tier> to <service>)
- All Connections/Flows for tier
- Flows >
TCP Flow Metric Descriptions
| Default Monitoring Mode | ||
# Client Limited |
The number of TCP window updates sent by a client node indicating that it is receiving data at a faster rate than the application can process |
KPI |
# Client Zero Window |
If a client's TCP buffer is full, it sends Zero as the TCP receive window size to indicate that it cannot receive more data. The data transfer then stops until the client can process the data in its buffer. A high rate of Client TCP Zero Window messages indicates a problem with either:
KPI |
# Connection Errors |
The sum of Syn Resets + Syn Blackholes + TCP Resets - Established |
KPI |
# Connection Requests |
The total number of connection requests (successful and unsuccessful) sent during the selected time window | KPI |
# Current Established Connections |
The number of established (setup) flows/connections | KPI |
# Data Retransmits |
Number of TCP data packets that were retransmitted for all TCP Connections | KPI |
# Delayed Acks (Data Piggy Back) |
The average number of times a receiving node sent an ACK (acknowledgment) by "piggybacking" the ACK onto another message | Advanced |
# Delayed Acks (Timeouts) |
The average number of times a receiving node sent an ACK (acknowledgment) because the Delayed ACK timer expired This is a "worst-case" delay for the Delayed ACK algorithm and occurs most often when Nagle's algorithm and Delayed ACK are enabled on the sending and receiving node, respectively. A high rate of delayed ACKs may contribute significantly to the average Latency on a Connection. |
Advanced |
# Errors |
The number of TCP messages sent indicating an error in setting up the connection (SYN errors), or tearing down the connection (FIN errors) | KPI |
# Fin Errors |
The number of errors generated while tearing down the connections (TCP FIN errors). Many connections in FIN wait states can cause delays in creating new connections. |
KPI |
# Flows (<1KB) # Flows (1k - 10k) # Flows (10k - 100k) # Flows (100k-1MB) # Flows (1MB - 10MB) # Flows (>10MB) |
Use these metrics to analyze the distribution of flows by throughput |
Advanced |
# Flows - Handshake (1SD) # Flows - Handshake (2SD) # Flows - Handshake (3SD) |
The number of TCP flows with connection-setup times that are 1, 2, or 3 Standard Deviations outside (higher or lower than) the average for that connection group
Under ideal conditions, all flows should be within 1SD of the average |
Advanced |
# Flows - Lifetime (1SD) # Flows - Lifetime (2SD) # Flows - Lifetime (3SD) |
The number of TCP flows with lifetimes that are 1, 2, or 3 Standard Deviations outside (higher or lower than) the average.
Under ideal conditions, all flows should be within 1SD of the average. 2SD or 3SD flows indicate inconsistent flow treatment along the network path. These inconsistencies can occur when a network service decreases the available bandwidth intentionally (bandwidth throttling) or prioritizes some types of traffic over others (traffic shaping). Short-lived connections, even if they are intermittent, may indicate an issue worth investigating. The more short-lived connections get generated, the more resources are spent setting up and tearing down these connections. |
Advanced |
# Flows - RTT (1SD) # Flows - RTT (2SD) # Flows - RTT (3SD) |
Number of flows whose Round Trip Times are 1, 2, or 3 Standard Deviations higher than the average for all flows in the parent group. Under ideal conditions, all flows should be within 1SD of the average. High-RTT connections, even if they are intermittent, may indicate an issue worth investigating. If the average response time for an eCommerce web app is two seconds (acceptable), but 5% of transactions are 20 seconds or higher (not acceptable), this can result in a significant number of unhappy customers and lost revenue. |
Advanced |
# Flows - TCP Data Rxmt |
Number of flows within which any packet was retransmitted. Retransmissions are an indication of packet loss. | Advanced |
# Flows - TCP Resets |
The average number of flows that were closed by a TCP Reset |
KPI |
# Flows - w/o TCP SACK |
Number of flows with the TCP Selective Acknowledgment (SACK) option disabled. With SACK enabled, a receiver can send SACK packets to acknowledge receipt of multiple data packets in the case of lost segments. This improves network performance by reducing the number of retransmissions. With SACK disabled, the receiver must resend all the packets after the last lost segment, even if they were received by the peer. |
Advanced |
# Flows - w/o TCP Timestamp |
Number of flows with the TCP Timestamp option disabled. Use this option to calculate more accurate Round Trip Times. | Advanced |
# IP Fragment Count |
The total number of IP fragments attributes to this TCP connection group. A high level of fragmentation indicates network issues which can severely affect application performance. | KPI |
# Loss Pkts |
The total number of packets that were lost (sent but never received) | Advanced |
# Nagle Delays |
The number of times a message-send event was delayed because the sending node had to wait for previously-sent data to be acknowledged (ACK'd). This occurs most often when Nagle's algorithm and Delayed ACK are enabled on the sending and receiving node, respectively. |
Advanced |
# PIE Events |
Use Performance Impacting Elements (PIE) to identify the location of actual or potential bottlenecks:
KPI |
# RetransmissionTimeouts |
Retransmission Timeouts (RTOs) indicate network packet loss which results in retransmission of data when the TCP retransmission timer expires (Timer to make sure data is ACK'ed)
KPI |
# SACK Retransmits |
Average number of packets that were retransmitted due to a SACK message that indicated an unreceived packet | KPI |
# Server Limited |
The number of TCP window updates sent by a server node indicating that it is receiving data at a faster rate than the application can process |
KPI |
# Server Zero Window |
If a server's TCP buffer is full, it sends Zero as the TCP receive window size to indicate that it cannot receive more data. The data transfer then stops until the server can process the data in its buffer. A high rate of Server TCP Zero Window messages indicates a problem with either:
KPI |
# Syn Blackholes |
The number of connection attempts that went unanswered and resulted in a failure. Syn blackholes can severely impact application performance. |
KPI |
# Syn Resets |
The number of connection attempts that were explicitly refused by the other host. Syn resets can severely impact application performance. |
KPI |
# TCP Resets - Established |
The average number of times an established TCP flow was reset |
KPI |
# TCP Resets - Fin |
The average number of times a TCP flow was reset while it was in the process of getting closed | KPI |
# TTL Changes (1 - 2 hops) # TTL Changes (3 - 4 hops) # TTL Changes (>=5 hops) |
The number of routing-hop changes experienced by this connection. Frequent variations in routing-hop changes indicate routing problems in the network and can severely affect app performance. Under ideal conditions, the number of hops should be consistent. |
Advanced |
Avg # TTL Hops |
The average number of routing-hop changes experienced by this connection | Advanced |
Delayed Acks Lag (usec) |
The average amount of lag that Delayed ACKs are adding to the overall Latency of the Connection | Advanced |
Initial RTT (usec) |
Round trip time for the initial two SYN packets (between SYN and SYN-ACK, or SYN-ACK and ACK depending upon whether the Agent is running on client or server) |
KPI |
Latency - RTT (usec) |
Average round-trip latency (from packet transmission to acknowledgment) for all packets |
KPI |
Lifetime (usec) |
Average lifetime (from initial setup to final teardown) for TCP sessions in the Connection group | KPI |
Loss (per mille) |
The number of packets lost per 1000 packets sent. "Per mille" is a percentage with one additional digit of precision. | KPI |
Nagle Delays Lag (usec) |
The average amount of lag that Nagle delays are adding to the overall Latency of the Connection | Advanced |
Pkts per Sec |
Average rate of packets sent and received | KPI |
Rx Pkts per Sec |
Average rate of packets received | Advanced |
Rx Throughput (BPS) |
Average rate of bytes received | Advanced |
TCP Handshake (usec) |
Round trip time for the initial three-way connection setup for all flows in the parent group:
KPI |
Throughput (BPS) |
Throughput (bytes per second) for the application of interest on all TCP sessions | KPI |
Tx Pkts per Sec |
Rate of packets sent | Advanced |
Tx Throughput (BPS) |
Rate of traffic received | Advanced |
