Discover and Upgrade the Controller on AWS
The Enterprise Console provides the discover_upgrade command that will discover your Controller, determine its version, and then upgrade it if needed.
bin/platform-admin.sh login --user-name <admin_username> --password <admin_password>
bin/platform-admin.sh submit-job --service controller --job discover-upgrade --args controllerPrimaryHost="<hostname>" controllerRootUserPassword="<password>" mysqlRootPassword="<password>" databaseType=aurora destinationDirectory="<controllerInstallationDirector>"
If your upgrade fails, you can resume by passing the flag useCheckpoint=true as an argument after --args.
If several versions of the Enterprise Console exist in your environment, the discover-upgrade command will fail if the --target-version argument is not included. For details on adding the --target-version argument, see Upgrade the Controller to the Latest.
