Monitor Observations
The Observations page describes the runtime events that do not violate a policy or that are not considered to be an attack. These can be normal runtime behavior where the events may impact the security, but any malicious intent is not determined. For example, an application opening a file outside the application directory causes Observed state. You can use this information in investigating incidents to understand the historical behavior of an application and in defining the runtime policy.
The Observations page includes these details:
| Name | Description |
| ID |
The ID of the corresponding Observation. Cisco Secure Application generates this ID. You can modify this ID on the Observation details page. To view the Observation details page, click the desired row. Click this field to sort the ID alphabetically. |
| Source |
The source of the corresponding Observation. This provides information on these types of the observation:
Click this field to sort the values alphabetically. |
| Events | The type of the observation and count of that observation type. |
| Observation Type |
Observation types include:
| Application |
The application affected by the observation. |
| Tier (Nodes) |
The tier name and the number of nodes. You can click |
| Last Detected |
The time that is elapsed since the last event within the observation. Click this field to sort the values in ascending or descending order. |
