Monitor Security Status of Applications
The Applications page focuses on the current state of security capabilities across applications, tiers, and nodes. You can control the security setting using the Configure permission, and identify issues with agents that are not registered or are inactive. You can use the filter to select the application or the tier scope. In the Applications table, you can click the application row to drill down to all of the tiers for that application. Also, you can click a tier row to drill down to the corresponding nodes. See Monitor Application Security Using Cisco Secure Application.
On the Applications page, you can view visualize these node details:
- Active: Nodes that are active for the corresponding application.
- Supported: Nodes with APM agents that are registered with Cisco Secure Application.
- Enabled: Nodes with security enabled.
- Secured: Nodes that are secured with the Cisco Secure Application policy.
- Total Active Nodes: Nodes with currently active registered APM agents.
- Ready: Nodes that can be successfully registered.
