Navigate to Splunk AppDynamics Application or Tier Flow Map
To navigate from the Secure Application dashboard to the Splunk AppDynamics flow map, click the flow map icon () that appears on these pages: Applications, Business Transactions, Libraries, Attacks. The flow map icon is associated with the selected scope for the Secure Application dashboard. See Select Scope for the Dashboard.
View Data Using Search Filter
The Secure Application provides a Search filter on various pages in the dashboard. The search filter allows you to search based on a selected category. For example, on the Business Transaction page, you can search by Business Transaction, Application, and Entry Tier.
You can select the required search category from the dropdown list, then click the Search field to view the list of values corresponding to the category. You can also find the required value as you type. If you do not require the exact match, you can enter the required generic value in the Search field. For example, consider that you want to search for all applications that start with a specific prefix, AD. You can select the search category as Application and enter AD in the Search field.
You can search using one or all the categories, but each category can have a single search value. A category is disabled when you specify a search value for that category, but you can continue to select another available category and specify its search value. These search values act as filters. You can remove the search values to remove the search filter.
