Default Values for Smart Agent CLI Utility Flag Options
It is recommend to use Smartagentctl instead of Smart Agent Command Line Utility. See Install Smart Agent.
| Option | Default Value |
version string (latest) ( -v ) profile string (default) ( -p ) config string ( -c ) install-dir string ( -d ) app-name string ( -a ) node-name string ( -n ) tier-name string ( -t ) inventory string ( -i ) connection string ( -q ) hosts string ( -m ) install-agent-from string ( -l ) backup string ( -l ) attach-configure-file string ( -f ) | latest default /opt/appdynamics/appdcli/config.ini "" "" "" "" "" local all "" false "" |
