Flow Map Interactions
On flow maps you can:
- Click once on an object to see key performance indicators in an informational popup.
- Double click an object to open a detailed flow map of that object.
Change the Time Range setting to have the flow map represent the activity of the system within the selected time frame.
Click and drag objects to rearrange the flow map layout.
Use the view and arrangement options at the top right to view as a list, auto-arrange for the fewest crossing flows, or maximize the view.
