Manage Flow Maps
In a large-scale deployment, the flow map may show hundreds of monitored nodes. You can create custom flow maps that target specific areas of interest.
You can configure it to show only certain tiers or those based on performance thresholds, for example:
  • Only show tiers from where the load exceeds fifty calls per minute and the average response time exceed 10,000 ms.
  • Only show backends receiving at least 400 calls per minute and generating more than 10 errors per minute.
To create, copy, or delete a flow map, click Application Flow Map > Manage My Flow Maps .
When you create a flow map, the new flow map inherits the context of the flow map in which it was created, whether created from an application, business transaction, tier, or node flow map.
