You enable development level monitoring in the context of a particular business
transaction/originating node combination. To avoid exceeding development mode limits described
in Development Level Monitoring
Limits, it is recommended that you enable development monitoring at the smallest
scope possible.
To enable development level monitoring:
In the business application for which you want to enable monitoring, clickConfiguration>Development Level Monitoring.
Enable the Development Level Monitoring switch at the top of the
page.
For agents <= 4.3, enabling development level monitoring applies globally, rather
than for a particular business transaction. For agents >+ 4.3, you need to configure
the business transaction and node to which the configuration applies, as described in the
following step.
Select the Business Transaction for which you want to enable development monitoring.
Click the Enabled checkbox next to the originating nodes on
which you want to enable development level monitoring.
