Use the Node Problem Viewer
If accessed from the Snapshot viewer, the Node Problem viewer displays node problems for the time range of the snapshot. If accessed from the Node dashboard, the Node Problem viewer uses the time range set in the Node dashboard. You can edit the time range in the Node Problem viewer and then apply the new time range. You can also define and save a custom time range.
The right panel of the Node Problem viewer displays the metrics that deviate the most from their baselines for the specified time range.
On the left, you can set filters on what data appears. Options include:
- The baseline to use to define node problems.
- The type of metrics, whether custom, hardware metrics, JVM, and so on.
Specify whether to display problems with values that are:
- Higher than baseline
- Lower than the baseline
- Higher and lower than baseline
For example, if you are only interested in CPU that is too high, set the Analysis Type to Higher for Hardware Resources. However, if you want to monitor the load on your machine continuously because low CPU usage would also be a problem, set the Analysis Type to Higher and Lower. The right panel shows the ten items that deviate the most from the baseline.
After changing an option, click Analyze Node Problems to apply the change.
