Monitor Business Transactions
This page includes details to monitor the vulnerability risk of a Business Transaction. Secure Application evaluates the risk of a business transaction using an algorithm that factors in exposure to the internet, access to potentially sensitive data, usage of vulnerable libraries, reached vulnerable code, prediction of vulnerability exploitation, unsafe external APIs, and runtime threat activity.
These factors enable you to prioritize what is required to triage, mitigate, and remediate, which reduces risk exposure to the business. You can use the Search filter for the Business Transaction, Application, and Entry Tier categories. See Monitor Application Security Using Secure Application.
Field Name Description
The name of the business transaction. To view the business transaction on the Splunk AppDynamics Controller, click the icon next to the name.
Application (Tiers)
The application name and the number of tiers that are part of the business transaction for the application. To view the application on the Splunk AppDynamics Controller, click the icon next to the name.
Entry Tier
The tier from which the transaction originates. To view the tier on the Splunk AppDynamics Controller, click the icon next to the name.
Business Risk The Business Risk algorithm is calculated based on the likelihood of vulnerability exploitation, and the impact of the potential exploitation in a business transaction. These are the three statuses for a Business Risk:
  • Normal 0-330
  • Warning 340-660
  • Critical 670-1000
The higher the value, the higher the risk for the application vulnerability.
Total Vulnerabilities
  • Critical
  • High
  • Medium
  • Low
The color-coded icons represent these severities.
Total Attacks The number of attacks based on their status:
  • Exploited
  • Blocked
  • Attempted
View Business Transaction Details
To view details for a specific business transaction, click any business transaction on the Business Transactions page.
The top pane is split into the following sections:
  • Business Risk Score, which includes six Business Risk Factors:
    • Vulnerabilities with High Exploitation Risk: Identifies business transaction vulnerabilities with Cisco Security Risk Score > 66.
    • Threat Activity: Identifies business transaction security events that match known attack types. See Monitor Attacks and Monitor Observations.
    • Usage of Unsafe External API: Identifies uses of external APIs that are unsafe.
    • Important Business Transaction: Identifies a business transaction that has a custom name.
    • Access to Datastore: Identifies a business transaction that has access to a datastore.
    • Publicly Accessible: Identifies a business transaction that is accessible from the internet.
  • Business Transaction: The name of the business transaction.
  • Application: The name of the application.
  • Daily Highest Business Risk Score Detected: A visualization of the Business Risk Score trend.
  • Top Recommended Actions: Top actions that you can take in order to remediate potential risks.
Vulnerabilities Tab
On the Business Transactions page, you can view the Vulnerabilities tab, which displays:
Title The vulnerability type involved in the business transaction.
ID
The Common Vulnerabilities and Exposure (CVE) identifier. You can click the name to view the details specific to that CVE.
  • Green 0-33
  • Amber 34-66
  • Red 67-100
Reached
If there is an exclamation mark in this column, it means this vulnerable code has been reached.
  • None 0-0
  • Low 0.1-3.9
  • Medium 4.0-6.9
  • High 7.0-8.9
  • Critical 9.0-10.0
Tier (Nodes)
The services or the tiers that are affected because of the selected vulnerability. The number indicates the number of affected nodes. The tier icon directs to the Splunk AppDynamics flow map for that tier.
Library The library affected because of the vulnerability. You can click the library to view the details of the library. See Monitor Libraries.
Last Detected The time duration since the vulnerability was last seen on the tier.
Status
  • Confirmed (manually set by user after review)
  • Fixed (vulnerability is fixed)
  • Ignored (manually set by user after review)
The Detected and Fixed statuses are automatically detected based on the libraries used in the application.
Attacks Tab
On the Business Transactions page, you can view the Attacks tab, which displays:
Name Description
ID
The ID of the corresponding Attack. Secure Application generates this ID. You can modify this ID on the attacks details page. To view the attack details page, click the desired row.
Outcome
  • Observed: When the events may impact the security, but any malicious intent is not determined. For example, an application opening a file outside the application directory causes Observed state.
  • Blocked: When the events are blocked based on the attack policy.
  • Exploited: When malicious activity is performed to impact the application's security.
  • Attempted: When the malicious activity is determined but not exploited.
Attack Type (Events) The type of the attack and count of that attack type.
Attack Trigger Relevant information from the runtime behavior resulting from the event where Secure Application determined a potential attack.
Tier
to launch the application flow map in the Splunk AppDynamics dashboard. The info icon (
) next to an affected tier indicates that the attacked nodes in the tier include critical or medium vulnerability.
Last Detected
The time that is elapsed since the last event within the attack. Click this field to sort the values in ascending or descending order.
Status
The status of the attack is defined as either Open or Closed. If you have Configure permissions, click the checkboxes for the required rows and then click the Set Status option to set the appropriate status. Click this field to sort based on the Open or Closed state.
