Monitor Vulnerabilities
| Cisco Security Risk Score is deprecated. |
Cisco Security Risk Score metrics are from an integration with Cisco Vulnerabilities Management (formerly Kenna Security), which is now at end-of-sale. The integration itself is still active but might be removed in a future release. |
The Vulnerabilities page displays the list of all the scanned vulnerabilities. An application registered with Secure Application is scanned, and continuously monitored for vulnerabilities. When vulnerabilities are detected, a user with the Configure permission can prioritize vulnerabilities. By default, this page displays an overview of the selected application. See Monitor Application Security Using Secure Application. Use the Search filter to search based on the Vulnerability, Package Language, CWE,Severity, Application, Tiers, Libraries, and Status values.
| Chart | Description |
Vulnerabilities By Severity |
Hover on the required severity to view the number of open vulnerabilities with that severity. If you require all the charts in the pane to display based on a specific severity, click the severity on the pie chart. To return back to the complete chart, click the same severity again. |
| Severity Trend | This chart displays the number of open tickets versus the number of fixed tickets from the last 7 days. This shows the trend of fixing open vulnerabilities. |
| Days Since First Detected | This chart displays the number of days the vulnerability is open versus the severity of the vulnerability (critical, high, medium, or low). |
| Title |
The name of the vulnerability. |
| ID | The Common Vulnerabilities and Exposure (CVE) identifier. You can click the name to view the details specific to that CVE. |
| Cisco Security Risk Score | The Cisco Security Risk Score provides an estimate of exploitation based on real-time events. These are the three statuses:
| Reached | The application uses the vulnerable method as part of its code flow. A yellow icon is displayed in this column to indicate that a vulnerability method is matched. |
| CVSS Score | This score is based on the Common Vulnerability Scoring System (CVSS) with five severities:
| Application | Name of the affected application. |
| Tier (Nodes) |
The services or the tiers affected because of the corresponding vulnerability. The number in parenthesis indicates the number of nodes. Click the flow map icon to view the Splunk AppDynamics flow map for that tier. Note that a node count of zero (0) means that a vulnerability isn't present in any of your active nodes. Splunk AppDynamics does not change the state of a fixed vulnerability to a confirmed vulnerability because that is a user-defined state. |
| Library | The library that exists in the corresponding application and tier. You can click the value in this field to view the list of all the vulnerabilities that impacts this library. |
| Last Detected | The time elapsed after the vulnerability was last detected. |
| Status |
The status Ignored can be updated by the developer with Configure permission for Secure Application. If you have Configure permissions, you can select the vulnerabilities using the checkbox, and then set the status by using the Set Status option. Without Configure permission, the Set Status option is unavailable. |
View Vulnerability Details
When you click on a specific vulnerability row, you can view detailed information about a vulnerability.
| Field Name | Description |
| Title |
| CWE | The Common Weakness Enumeration ID for the corresponding vulnerability. |
| Publish Date | The date in which the details were published. |
| First / Last Seen | The timeframe when the vulnerability was first detected and when the vulnerability was last detected. |
| Type |
The vulnerability type. |
| Remediation |
The recommended remediation action. In the case of a vulnerable library, the version(s) to upgrade the library for remediation. Click on show all <count of versions> to view all the recommended remediation versions. |
| Overview | The overview of the vulnerability. |
| Tier (Nodes) |
The services or the tiers affected because of the corresponding vulnerability. The number in parenthesis indicates the number of nodes. Click the flow map icon to view the Splunk AppDynamics flow map for that tier. Note that a node count of zero (0) means that a vulnerability isn't present in any of your active nodes. |
| Last Detected | The time elapsed since the vulnerability is detected. |
| Status |
If you have Configure permissions, you can select the rows using the checkbox, and then set the status by using the Set Status option. Without Configure permission, the Set Status option is unavailable. The Detected and Fixed status are automatically detected based on the libraries used in the application. |
