KPI Metrics in Network Dashboard and Application Flow Map
Some network metrics are considered Key Performance Indicators (KPIs) because they are essential measures of whether the network or a specific part of the network, is performing successfully. Network Agents collect network KPIs for all monitored tiers, nodes, network links, and application flows. You can view KPI metrics for these elements:
View Network KPIs
For the Entire Application
The Network Dashboard includes Throughput, TCP Loss, and PIE charts that measure network health for the entire application.
For a Network Link
- Network Dashboard–The flow map shows KPIs for each link. Click a link to view KPI time charts and KPIs per Connection.
- Right-click dashboard–Right-click a link in the Network Dashboard and select View Metrics. See KPI Metrics in Right-Click Dashboards.
For a Tier
- Network Flow Map–Click a tier to view KPI time charts.
- Right-click dashboard–Right-click a tier in the Network Dashboard and select View Metrics. See KPI Metrics in Right-Click Dashboards.
For a Node
- Tiers & Nodespage – Set the Show Data menu to Network. The table shows network KPIs and the Network Agent status for each node.
- Node Dashboard– Right-click the node and select View Metrics. See KPI Metrics in Right-Click Dashboards.
For a Connection
Connections Explorer – Access the Network Dashboard and select Connections. The Explorer shows network KPIs for all network links. Drill down into a network link to view the Connections used on that link. If a Network Agent has collected metrics for a Connection, you can:
- View network KPIs in the Explorer table.
- Right-click and select View Metrics. See KPI Metrics in Right-Click Dashboards.
- Right-click and select View Metric Browser. See TCP Connection Metrics in Metric Browser.
KPI Metric Descriptions
| Metric | Description | Default Monitoring Mode |
| Throughput |
The average rate of Application X traffic sent and received over one Connection, or a set of Connections. Correlated spikes along with Response Time indicate bottlenecks. |
KPI |
| Latency |
The average TCP Latency (round-trip time) for a packet to go from one application tier the other, and back again. When TCP effects are not significant, Latency primarily measures network round trip times. Network latency is primarily a factor of the physical distance between two nodes and remains consistent over time. Correlated spikes along with Response Time indicate that TCP effects between two tiers (such as packet queueing and delayed acknowledgments) are affecting application performance. |
KPI |
| TCP Loss (mille) |
The average number of packets (per 1000) that were sent but never received. Packet loss can degrade application performance significantly. TCP detects and re-transmits lost packets; this ensures reliable transmission but introduces delays.
KPI |
| Errors | The number of TCP messages sent indicating an error in setting up the connection (SYN errors) or tearing down the connection (FIN errors) for a specific TCP session. | KPI |
| PIE (Performance Impacting Events) |
The rate of PIE (Performance Impacting Events), which indicate performance issues on one node, both nodes, or the network between two nodes:
KPI |
