Customize Splunk Mission Control incident settings
Customize Splunk Mission Control incident settings to match your incident response procedures. You can add or modify status or disposition values to align with the terms used at your organization to respond to security incidents.
After you add custom status or disposition values, analysts can use those values when triaging incidents. See Triage incidents using incident review in Splunk Mission Control.
You can also create incident types, custom fields, and service-level agreement (SLA) conditions to personalize your incident response workflow.
Customize incident settings from other Splunk security products
Users of Splunk security products can utilize single sign-on (SSO) across Splunk Cloud Platform to seamlessly navigate between apps. From Splunk Mission Control, you can access other Splunk security apps, such as Splunk Enterprise Security (Cloud) and Splunk SOAR (Cloud), without using your credentials to sign in again.
Some features of Splunk Mission Control link directly to other security apps. For example, if you're signed in to Splunk Mission Control, you can pivot to Splunk Enterprise Security (Cloud) from the Settings page of Splunk Mission Control. If you want to change the status settings for incidents in Splunk Mission Control, navigate to Settings and select Incident settings then Status settings to open Splunk Enterprise Security (Cloud) and adjust the settings without using your credentials to navigate between products.
Customize the incident type macro
As Splunk Mission Control ingests incidents, the incident type macro assigns particular incidents to incident types. This global macro determines a hierarchy of conditions across all incident types, so it must define each incident type.
Using the Search Processing Language (SPL), you can edit the incident type macro by navigating to Settings in Splunk Mission Control and selecting Incident settings then Incident type macro. The following code is an example of a macro that matches incidents with more than 20 risk events to one incident type and also matches incidents with an urgency of medium to another incident type.
eval incident_type=case(risk_event_count>20, "incident_type_1", urgency=="medium", "incident_type_2")
See Search with incident data in Splunk Mission Control to learn more about incident data you can leverage with SPL in the incident type macro.
Create incident types
You can create incident types to categorize your incidents by use case or source.
To create an incident type, follow these steps:
- From the Settings page in Splunk Mission Control, select Incident Settings then Incident type.
- Select + Incident type.
- Enter a name for the incident type. You cannot change the name of the incident type after you create it.
- (Optional) Enter a description for the incident type.
- (Optional) Edit the macro for the incident type in the Incident type matching macro field. This macro matches incidents with incident types as Splunk Mission Control ingests them. For example, you can use
eval incident_type = case( severity == "medium", "Phishing")to assign the incident type ofPhishingto all incidents with a severity ofmediumwhen Splunk Mission Control ingests them. The incident type macro is a global macro that determines a hierarchy of conditions across all incident types. You can edit the macro while creating a new incident type, or you can edit the macro by navigating to Settings and selecting Incident settings then Incident type macro.Note: Use thecasestatement in the macro to make sure that the macro applies to all incident types.- Save the macro.
- Select See your macro in action to check the status of your macro on the Search page.
- Select Save.
- (Optional) You can edit an incident type you've already created by selecting the incident type in the Incident types table. You can assign new response templates and custom fields to the incident, or remove ones from it.
You can also associate an incident type with other Splunk Mission Control features, such as a response template. See Associate an incident type with a response template.
Customize status settings
You can customize Splunk Mission Control status settings in Splunk Enterprise Security (Cloud).
- From the Settings page in Splunk Mission Control, select Incident settings then Status settings. You are then redirected to Splunk Enterprise Security (Cloud).
- In Splunk Enterprise Security (Cloud), manage and customize the investigation statuses for your incidents.
Customize incident review and disposition settings
You can customize Splunk Mission Control disposition settings in Splunk Enterprise Security (Cloud).
- From the Settings page in Splunk Mission Control, select Incident settings then Dispositions. You are then redirected to Splunk Enterprise Security (Cloud).
- In Splunk Enterprise Security (Cloud), manage the incident review settings and dispositions.
Create a custom field
A custom field is a unique label that you can assign to an incident to help with your investigation in Splunk Mission Control. For example, if you want to investigate phishing incidents by tracing the emails back to their sources, you can create a custom field like originating sender and assign the phishing incident type to it to accelerate the investigation. You can view and edit custom field values for an incident in the Overview tab.
Unlike summary fields, which apply only to the incidents for which you create them, custom fields apply to all or specific incident types. See Create a summary field for an incident for more information about summary fields.
To create a custom field, complete the following steps:
- From the Settings page in Splunk Mission Control, select Incident settings then Custom fields.
- Select + Custom field.
- Give your field a name.
- Decide whether you want your custom field to be global. Global custom fields apply to all incidents.
- (Optional) To assign an incident type to your custom field, select No for Global Field, and then enter the incident type. You can either enter the name of an existing incident type or create a new one.
- Select a data type and then a field type. If you select Selection for field type, add field values.
- Decide whether you want to allow inline editing for the custom field value. Select the Allow inline editing check box to automatically save edits made to the field value in the Overview tab of an incident. If you deselect the check box, you can still edit the custom field value along with other summary field values. See Edit field values for an incident.
- Select whether or not you want to require a custom field value before closing an incident. Selecting Yes for Resolution needed requires a user to enter a value for the custom field in the Overview tab of their incident investigation before they can close the incident.
- Select Confirm.
Manage custom fields
You can manage your existing custom fields in the custom fields table by deleting the ones you no longer want and by reordering the ones you do. You can also edit the properties of a custom field you already created.
To start managing custom fields, navigate to Settings in Splunk Mission Control and select Incident settings then Custom fields. Then, follow the steps in this table for each type of action:
| Action | Steps |
| Delete | Select the trash can icon ( |
| Edit | Select the pencil icon ( |
| Reorder | Select and drag the move icon ( |
Customize SLA settings
A service-level agreement (SLA) in Splunk Mission Control represents a deadline for responding to or remediating an incident. You can use SLAs to prioritize your incident response. For example, you can sort incidents on the Incident review page from the soonest to latest SLA time.
Manage conditions for an incident SLA
You can change the default SLA time for all incidents, and you can apply different SLA times to incidents that meet particular conditions.
The default SLA time for incidents is 24 hours. To change the default incident SLA time, complete the following steps:
- From the Settings page in Splunk Mission Control, select Incident settings then SLA.
- Enter a time for the Default incident SLA and select the appropriate unit of time.
- Select Save changes.
To add an incident SLA condition, complete the following steps:
- Select + Condition.
- Enter the name of your condition and a new SLA time.
Note: You can't use special characters, such as
#,%, or&, in your SLA name. - Select the appropriate unit of time.
- Complete the conditional statement by selecting an incident field, an operator, and a value. For example, to apply an 8-hour SLA time for incidents that don't have a phishing incident type, select the
!=operator and enter 8 hours for incident type and phishing. Splunk Mission Control supports the following operators for SLA conditions:==,!=, andin.To learn more about operators, see Relational operators in the SPL2 Search Manual. - (Optional) If you want to add another conditional statement, select the add icon (
- Select Save.
You can edit existing SLA conditions and delete the ones you no longer want. To edit and delete SLA conditions, complete the following steps:
- If you want to edit an existing SLA condition, expand the condition you want to edit.
- Make the changes.
- If you want to delete an incident SLA condition, select the trash icon (
) next to the condition you want to delete, and then select Delete.
You can also view the SLA deadline, status, and condition of a particular incident from the Incident review page and modify the condition by selecting the SLA condition link.
