Monitor Kubernetes (classic navigator)
Learn how to monitor Kubernetes resources with Splunk Observability Cloud.
Note:
This page describes the classic Kubernetes navigator. For documentation on the new Kubernetes experience, see Monitor Kubernetes entities.
This page describes features specific to Kubernetes navigators. For information on features shared by all navigators, see Use navigators in Splunk Infrastructure Monitoring.
Monitor and troubleshoot Kubernetes instances with Splunk Observability Cloud navigators. Splunk Observability Cloud uses the Splunk Distribution of OpenTelemetry Collector for Kubernetes to provide robust infrastructure monitoring capabilities.
Use Kubernetes navigators to:
  • Get an overview of your Kubernetes infrastructure.
  • Monitor the health of your Kubernetes infrastructure.
  • Identify and diagnose an issue with your Kubernetes infrastructure.
  • View services and hosts running on Kubernetes.
For the full list of supported Kubernetes navigators, see Available navigators.
To start monitoring Kubernetes resources, you must:
Access Kubernetes navigators
By default, Splunk Observability Cloud shows the new Kubernetes entities page instead of the classic Kubernetes navigator experience.
To optionally switch back to the classic Kubernetes navigator experience, use the Splunk Observability Cloud main menu to select Infrastructure > Kubernetes entities. Then select Switch to previous experience.
Refine your view with the left navigation panel
Use the left navigation panel to quickly switch between Kubernetes entity types, search for filters, use predefined filters, and view or use recently used filters. This panel is available in all Kubernetes navigators and views.
To refine your view with the left navigation panel, use the following features:
  • Kubenetes <entity_type>: The name of this drop-down menu updates based on the selected Kubernetes entity type. Use the drop-down menu to switch between Kubernetes entity types..
  • Refine by: Use this panel to search for filters, use predefined filters, or view and use recently used filters. The list of predefined filters is searchable and organized by Relationship and Attribute.
Monitor entity performance with the Overview tab
Note: The Overview tab is only available on the Kubernetes nodes and pods navigators.
The Overview tab displays by default when you select the Kubernetes nodes or pods navigators. This view includes a dashboard that summarizes the performance of the selected entity type. Use this view to quickly identify the instances that consume the most resources, cause the highest number of errors, and contribute to slowing down your infrastructure.
This view also includes the K8s analyzer, K8s events, and Dependencies tabs.
Investigate instances with the hierarchy map
Note: The hierarchy map is only available on the detail view of the Kubernetes nodes, pods, and containers navigators.
Monitor your Kubernetes infrastructure with an interactive hierarchical map that displays the child resources associated with a selected Kubernetes instance. You can select elements in the map to drill down into them, or use the filter to explore your data. The level of detail shown on the map is dynamic and depends on the number of elements shown.
To navigate to the hierarchy map:
  1. In the Splunk Observability Cloud main menu, select Infrastructure > Overview and then Kubernetes.
  2. Select the Kubernetes nodes, pods, or containers navigator.
  3. Navigate to the table view:
    1. If you selected the Kubernetes nodes or pods navigator, select the Table tab.
    2. If you selected the Kubernetes containers navigator, no action is required. The table view displays by default.
  4. In the table, select an instance name to navigate to the detail view.
  5. Expand the Hierarchy Map.
Hierarchy map features
On the hierarchy map, nodes, pods, and containers are colored by health and status, as reported by Kubernetes:
  • Nodes are colored by condition: Node Ready, Memory Pressure, PID Pressure, Disk Pressure, Network Unavailable, and Out of Disk
  • Pods are colored by phase: Running, Pending, Succeeded, Failed, and Unknown
  • Containers are colored by status: Ready, Not Ready, and Unknown
To investigate instances with the hierarchy map, use the following features:
  • Breadcrumb navigation: Switch to different instances and jump across entity levels using the breadcrumb navigation bar.
  • Hover: Get more information about an instance, including its status or phase, by hovering over that instance.
  • Select and zoom: Drill down into an instance and change the zoom level of the map, if applicable, by selecting the instance.
  • Filter: Filter the map by any available metadata in your Kubernetes data, such as a namespace, a workload, or any other key-value pair. When you apply a filter, the map highlights instances that match the filter. You can still hover over the dimmed instances to view details about them.
View Kubernetes events associated with an instance
Note: The K8s events tab is only available on the overview and detail views of the Kubernetes nodes and pods navigators. This feature requires enabling Log Observer Connect.
Select the K8s events tab to view an events rate chart that groups events by severity and a searchable table that lists the Kubernetes events associated with the entity type.
Search embedded logs
Note: This feature is only available on the overview and detail view of the Kubernetes nodes navigator.
Search for specific keywords within logs embedded in Kubernetes navigators for faster troubleshooting and log analysis. Your search does not affect the Log Chart Summary, ensuring data integrity.
To search embedded logs:
  1. Select the K8s node logs tab.
  2. In the search bar next to the System logs header or the Authentication logs header, search for the keyword that you want to find in embedded logs.
    Note: Searches are case insensitive and treat the keywords you enter as a single string, aligning with Log Observer Connect behavior. When you view the logs in Log Observer Connect, the search persists to maintain context.
Troubleshoot performance with the Kubernetes analyzer
Note: The Kubernetes analyzer is only available on the:
Select the K8s analyzer tab to access the Kubernetes analyzer. The analyzer helps you troubleshoot Kubernetes problems at scale by highlighting Kubernetes instances that are in a bad state, such as nodes that are not ready. The analyzer produces theories about what those instances might have in common, such as that all of the instances are running the same workload or all instances are located in the same AWS region. Select a finding in the analyzer to filter the map.
The analyzer displays suggested filters for the elements selected in the table or heat map view. Select links in the analyzer to add filters to the table or heat map view and explore conditions across your entire Kubernetes environment.
The analyzer uses AI-driven insights to examine potential patterns between nodes, pods, or containers. The trouble indicators are:
  • Pods that are in pending status
  • Pods that are in failed status
  • Pods with unknown condition
  • Containers with high restart counts
  • Nodes not ready
  • Nodes with unknown condition
  • Nodes experiencing high CPU
  • Nodes experiencing high memory
The analyzer displays overrepresented metrics properties for known conditions, such as pods in pending status, pods in failed status, and so on. You can use properties that are highly correlated with these conditions to filter the table or heat map.
You can also explore data about each of those elements in the navigator using context-sensitive dashboards. This enables you to identify the underlying patterns noticeable on the filtered map that might be correlated with Kubernetes issues. For example, if all failed pods are in certain types of clusters, the analyzer provides suggested paths to follow to troubleshoot such issues.
