Monitor Kubernetes entities
Monitor and troubleshoot Kubernetes instances with Splunk Observability Cloud.
This page describes the new Kubernetes monitoring experience. For documentation on the classic Kubernetes navigator, see Monitor Kubernetes (classic navigator).
Feature availability depends on your Splunk Distribution of the OpenTelemetry Collector for Kubernetes version. Use version 0.138.1 or higher for access to all features. For upgrade instructions, see Upgrade the Collector for Kubernetes.
Monitor and troubleshoot Kubernetes instances with Splunk Observability Cloud. Splunk Observability Cloud uses the Splunk Distribution of OpenTelemetry Collector for Kubernetes to provide robust infrastructure monitoring capabilities.
Use the Kubernetes entities page to:
Get an overview of your Kubernetes infrastructure.
Monitor the health of your Kubernetes infrastructure.
Identify and diagnose an issue with your Kubernetes infrastructure.
View services and hosts running on Kubernetes.
To monitor Kubernetes instances with the Kubernetes entities page, you must meet the following requirements.
You have configured data collection from Kubernetes. For instructions, see Collect Kubernetes data.
You have a user role with the following permissions:
READ_NAVIGATOR: Required to view navigator data.READ_DASHBOARD: Required to view dashboards.EXECUTE_SIGNAL_FLOW: Required to run SignalFlow API calls.
Access the Kubernetes entities page
To access the Kubernetes entities page, use the Splunk Observability Cloud main menu to select .
To optionally switch back to the classic Kubernetes navigator experience, select Switch to previous experience.
Monitor Kubernetes instances with aggregate views
On the Kubernetes entities page, you can monitor all Kubernetes instances of a selected entity type using the Table, Dashboard, and Heatmap tabs.
The following sections describe how to use the aggregate views:
View or pause real-time Kubernetes data
By default, the Kubernetes entities page streams real-time data with a minor delay and displays the most recent data point. The LIVE icon next to the time filter appears when the configured time range ends with Now.
Select the pause button to set the ending time range to the current time. To set the ending time range to Now again, select the play button. The starting time range isn't affected by either action.
Customize the table view for Kubernetes entities
On the Kubernetes entities page, the Table tab is selected by default. The table displays the list of Kubernetes instances with customizable columns for metrics and attributes.
To customize the columns in the table, select the gear icon in the upper-right corner. The drop-down menu displays the current columns in the table. Use the drop-down menu to add, remove, and reorder table columns.
View and filter by OpenTelemetry tags in the table view
To view OpenTelemetry tag keys or values in the table view, follow the steps to customize the table view. You can use the drop-down menu to add a table column for:
Tags, which displays all OpenTelemetry tag keys for each instance.
A specific tag key. The column displays the tag value for each instance with a matching tag key.
The table displays the first tag key or value for each instance. To view the full list, select the +<number> button next to the first tag key or value.
When you select the +<number> button for an instance, you can use the Search bar above the table to filter the list by specific tag keys or values.
Monitor entity performance with the Dashboard tab
On the Kubernetes entities page, select the Dashboard tab to display a dashboard that summarizes the performance of the selected entity type.
Use this view to quickly identify the instances that consume the most resources, cause the highest number of errors, and contribute to slowing down your infrastructure.
Monitor Kubernetes pod statuses
On the Kubernetes entities page, select Pods from the Kubernetes entities drop-down menu. The table of pods includes a Status column. When you select the name of a pod, the detail view also displays the status next to the pod name.
| Pod status name | Description |
| Pending | The pod has been accepted by the Kubernetes cluster, but one or more of the containers has not been set up and made ready to run. This includes the time a pod spends waiting to be scheduled as well as the time spent downloading container images over the network. |
| Running | The pod has been bound to a node, and all of the containers have been created. At least one container is still running, or is in the process of starting or restarting. |
| Succeeded | All containers in the pod have terminated successfully and will not be restarted. |
| Failed | All containers in the pod have terminated successfully and will not be restarted. |
| Evicted | The pod has been terminated and removed from a node by the kubelet. This typically occurs due to resource pressure on the node. |
| NodeAffinity | The pod cannot be scheduled onto a node because the node's labels do not satisfy the node affinity rules defined in the pod's specification, or in the PersistentVolume (PV) associated with the pod. |
| NodeLost | The node has become unreachable by the control plane, causing the pods on that node to enter an Unknown state. |
| Shutdown | The pod has been terminated. |
| UnexpectedAdmissionError | The pod was rejected during the admission process, meaning the kubelet was unable to admit or start the pod on the node. |
| CrashLoopBackOff | The backoff delay mechanism is currently in effect for a given container that is in a crash loop, or failing and restarting repeatedly. |
| CreateContainerConfigError | The pod cannot be created because there is an issue with the configuration specified for one of its containers. |
| ErrImagePull | The kubelet on the node where the pod is scheduled was unable to successfully pull the container image specified in the pod's definition from the container registry. |
| ImagePullBackOff | The pod is unable to start because the container image specified in its configuration cannot be pulled from the container registry. |
| Error | One of the containers in the pod exited with a non-zero exit code, indicating atypical shutdown. |
| ContainerCannotRun | A container within the pod failed to start successfully. |
| Unknown | The state of the pod could not be obtained. This typically occurs due to an error in communicating with the node where the pod should be running. |
Troubleshoot performance with the Kubernetes analyzer in aggregate views
This feature is available for Kubernetes nodes, pods, and containers.
In any aggregate view on the Kubernetes entities page, select the Kubernetes analyzer icon next to the Group by drop-down menu to analyze the performance of the selected entity type.
For more information on using the Kubernetes analyzer, see Troubleshoot performance with the Kubernetes analyzer.
Configure a Kubernetes entity type to require a filter to display data
When a Kubernetes entity exceeds the metric time series (MTS) limit processed in a signal, the aggregate views on the Kubernetes entities page display only a subset of the data until you apply a filter to limit the results. For more information on MTS limits, see Maximum number of metric time series processed in a signal.
MTS limit violations can cause low responsiveness on the Kubernetes entities page. To prevent this, you can configure a Kubernetes entity type to require a filter to display data. When you configure this setting, both the aggregate views for the entity type and the Kubernetes overview page will not display data until a filter is added.
Complete the following steps to configure a Kubernetes entity type to require a filter to display data:
In any aggregate view on the Kubernetes entities page, select the actions menu (...) in the upper-right corner.
Check the box for Require filters for data display.
Monitor a Kubernetes instance with the detail view
On the Kubernetes entities page, select the name of a Kubernetes instance to navigate to the detail view to explore more information about the instance.
The following sections describe how to use the detail view:
Investigate instances with the cluster map
This feature is available for Kubernetes clusters, nodes, pods, and containers.
In the detail view for an instance, select the Cluster map tab to monitor your Kubernetes infrastructure with an interactive hierarchical map that displays the child resources associated with the selected instance. You can select elements in the map to drill down into them or use the filter to explore your data. The level of detail shown on the map is dynamic and depends on the number of displayed elements.
View Kubernetes events associated with an instance
In the detail view for an instance, select the K8s Events tab to view an events rate chart that groups events by severity and a searchable table that lists the Kubernetes events associated with the entity type.
Search embedded logs
Search for specific keywords within logs embedded in Kubernetes entities for faster troubleshooting and log analysis. Your search does not affect the Log Chart Summary in Log Observer Connect, ensuring data integrity.
To search embedded logs, navigate to the detail view for an instance and select the Logs tab. Use one of the search bars to search for the keyword that you want to find in embedded logs.
Searches are case insensitive and treat the keywords you enter as a single string, aligning with Log Observer Connect behavior. When you view the logs in Log Observer Connect, the search persists to maintain context.
In the detail view for an instance, select the Analyzer tab to access the Kubernetes analyzer. The analyzer helps you troubleshoot Kubernetes problems at scale by highlighting Kubernetes instances that are in a bad state, such as nodes that are not ready. The analyzer produces theories about what those instances might have in common, such as that all of the instances are running the same workload or all instances are located in the same AWS region.
The analyzer displays suggested filters for the elements selected in the table view. Select links in the analyzer to add filters to the table view and explore conditions across your entire Kubernetes environment.
The analyzer uses AI-driven insights to examine potential patterns between nodes, pods, or containers. The trouble indicators are:
Pods that are in pending status
Pods that are in failed status
Pods with unknown condition
Containers with high restart counts
Nodes not ready
Nodes with unknown condition
Nodes experiencing high CPU
Nodes experiencing high memory
The analyzer displays overrepresented metrics properties for known conditions, such as pods in pending status, pods in failed status, and so on. You can use properties that are highly correlated with these conditions to filter the table.
View and compare YAML configuration files for a Kubernetes instance
This feature is available for Kubernetes pods and is enabled by default in versions 0.138.1 or higher of the Splunk Distribution of the OpenTelemetry Collector for Kubernetes.
For instructions on how to enable this feature in lower versions of the Collector, see Collect YAML configuration files with the Collector for Kubernetes version 0.138.1 and lower.
In the detail view for an instance, select the YAML tab to display the configuration file for the instance. You can use this tab to compare deployment versions and debug errors. For example, you can compare the arguments that were passed to your applications.
Splunk Observability Cloud displays YAML files up to 7 days old. By default, YAML files are collected every 6 hours. To update the collection interval, update the interval value in your Collector values.yaml file. For instructions, see Collect YAML configuration files with the Collector for Kubernetes version 0.138.1 and lower.
In the YAML tab, you can:
Enable the Compact Manifest setting to show only relevant metadata in the configuration file.
Use the table of contents on the right side to navigate between sections of the YAML file.
Select Compare and use the drop-down menus to select two YAML files. Each YAML file is identified by the timestamp that it was collected.
By default, the Split view displays the two YAML files and their differences side by side. Select Unified to show the differences as part of a single file.
Monitor the status of a pod over time
In the detail view for a pod, select the Pod lifecycle tab to display a timeline of the pod's status and events over a selected time interval. The time interval is set to 4 hours by default, but can be changed to 12 hours or 24 hours. In this tab, you can:
Hover over a segment in the Pod Status timeline to view additional metadata.
Select a segment in the Pod events timeline to display a table with more details about the events.
For more information on pod statuses, see Monitor Kubernetes pod statuses.
Monitor the alerts for a Kubernetes instance
In the detail view for an instance, select the Alerts tab to view an Alert severity distribution graph and a list of the alerts for the instance.
Investigate Kubernetes alerts with AI root cause analysis
Use AI root cause analysis (RCA) to investigate alerts affecting Kubernetes instances. AI RCA analyzes available Kubernetes health data and surfaces potential causes directly in the instance detail view, helping you move from an alert to an investigation without leaving the current page.
To access AI RCA, navigate to the detail view for a Kubernetes instance and view the Insights section. AI RCA is only available if a supported alert is present.
Monitor the relationships of a Kubernetes instance
The relationship map shows the first 100 related instances. Each entity type is denoted by its own icon and color. If health is degraded, the node for the instance includes a yellow (warning status) or red (critical status) border.
From the relationship map, you can:
Use the search bar to search instances by name. The search bar only appears when the relationship map includes more than 10 instances.
View a panel with metadata about the selected instance. You can select a related instance from the map to view its metadata in the panel. After selecting a related instance, you can drill down to the detail view for the instance by selecting Make root node or selecting the node twice. Drill down isn't supported for namespace and node entities.
Update your view by selecting the icons in the upper-right of the relationship panel.
The Top-down icon shows the hierarchical view based on parent-child relationships.
The Constellation icon shows shared relationships, lateral connections, and overlapping nodes without rigid top-down levels.
At the pod and container level, the relationship map can also show APM service associations. From an APM service node, select the service name to navigate to the corresponding APM service view.
