Monitor the status and top issues of your Kubernetes environment
Use the Kubernetes overview page for a high-level understanding of your Kubernetes environment.
Monitor the status and top issues of your Kubernetes environment with the Kubernetes overview page.
Use the Kubernetes overview page to:
  • Understand the count and percentage of entity types in your environment.
  • Monitor the status of the nodes and pods in your environment at a glance.
  • View the top issues for your Kubernetes entities over time.
To monitor Kubernetes instances with the Kubernetes overview page, you must meet the following requirements.
  • You have configured data collection from Kubernetes. For instructions, see Collect Kubernetes data.
    Note:
    This feature requires the metrics and dimensions collected by default with the Collector for Kubernetes. For more information, see Collected metrics and dimensions for Kubernetes.
  • You have a user role with the following permissions:
    • READ_NAVIGATOR: Required for viewing navigator data.
    • EXECUTE_SIGNAL_FLOW: Required for running SignalFlow API calls.
    • READ_ALERT: Required for viewing alerts. Without this permission, the page will still load but inline alerts will not be visible.
Access the Kubernetes overview page
To access the Kubernetes overview page, use the Splunk Observability Cloud main menu to select Infrastructure > Kubernetes overview.
Monitor the status of your Kubernetes environment
On the Kubernetes overview page, the Inventory section displays panels that you can use to understand the composition and status of your Kubernetes environment.
The following table describes the Inventory panels and how you can use them.
Panel name Use this panel to
Clusters
View the number of clusters in your environment.
Select the panel to navigate to the Kubernetes entities page with the Clusters entity type selected.
Namespaces
View the number of namespaces in your environment.
Select the panel to navigate to the Kubernetes entities page with the Namespaces entity type selected.
Workloads
View the percentage of workload types that make up your environment.
Hover over a segment in the pie chart to view the count of a type.
Nodes
View the percentage of nodes in Ready, Not Ready, and Unknown status.
Hover over a segment in the pie chart to view the count of the status.
Pods
View the percentage of pods in various statuses. Hover over a segment in the pie chart to view the count of the status.
For more information on pod statuses, see Monitor Kubernetes pod statuses.
Monitor the top issues in your Kubernetes environment
On the Kubernetes overview page, the Top issues section displays tabs that you can use to identify issues with your Kubernetes environment.
The following table describes the Top issues tabs and the threshold for each issue.
Issue name Threshold
Degraded deployments The deployment has fewer pods available than desired pods.
Failed jobs The job completion status is Failed.
Degraded DaemonSets The DaemonSet isn't running on all desired nodes.
Degraded StatefulSets The StatefulSet doesn't have the desired number of running pods.
Degraded nodes The status of the node isn't Ready.
Monitor and optimize your resource allocation for workloads from the Kubernetes overview
On the Kubernetes overview page, the Workload optimization - starvation risk chart displays the proportion and number of workloads that are at starvation risk, or risk of running out of CPU or memory. Select view all on the chart to navigate to the Workload optimization page, which you can use to monitor and optimize the resource allocation of your workloads.
For more information on using this page, see Monitor and optimize your resource allocation for Kubernetes workloads.
Configure the Kubernetes overview page to require a filter to display data
Note: You must be a Splunk Observability Cloud admin to use this feature.
If any entity type on the Kubernetes entities page is configured to require a filter to display data, the Kubernetes overview page automatically requires a filter to display data. This configuration prevents low responsiveness on both pages when they exceed the maximum number of metric time series (MTS) processed in a signal.
For more information on this feature, see Configure a Kubernetes entity type to require a filter to display data.
