Finding documentation in the Help Portal
Find documentation on the Splunk Help Portal using the global site header, through search, or from the product tiles on the homepage.
You can find documentation on the Splunk Help Portal in these ways. To return to the homepage, select the Splunk icon in the upper-left corner.
Using the site header
If you're browsing for documentation and want to look for documentation in a different product area, hover over the header to navigate to the product or manual you're looking for.
Screenshot of the global site header on help.splunk.com
Using the product tiles
Through the homepage, you can browse using the product tiles and explore the content in each category.
Screenshot of the Splunk Help Portal home page, showing product tiles
Searching the site
You can also search for specific documentation using the search bar:
Screenshot of the search bar
You can use Boolean operators, such as AND, OR, and NOT, to filter your search in addition to the filters available on the search results page. For example, the following search looks for scenario documentation for Splunk Enterprise Security:
CODE
scenario AND "Enterprise Security"
