Selecting versions in the Help Portal
Use the version selector on the Splunk Help Portal to find documentation and release notes for specific product versions, including maintenance releases.
The Splunk Help Portal hosts documentation for multiple versions of products, and you can use the version selector to choose the product version relevant to you.
For most products, the version selector allows you to choose the major.minor version, such as 9.4, instead of every major.minor.maintenance version, such as 9.4.1 and 9.4.2.
Note: Some versions are not yet available.
Where to find maintenance releases
When you select a major.minor version, like 9.4, it includes details for all related maintenance releases, such as 9.4.1 and 9.4.2. You don't need to navigate separately for each maintenance release.
As an example, all relevant updates and documentation for 9.4.1 and 9.4.2 is organized under version 9.4.
Examples
Release notes are the most commonly updated pages for maintenance releases. Here are a few examples to show how you can find information on known and fixed issues for each release.
You can find Splunk Enterprise 9.4 known issues under the 9.4 version selector:
Known issues for Splunk Enterprise 9.4.0, 9.4.1, and 9.4.2 are shown under the 9.4 version selector.
You can find Splunk Enterprise 9.4 fixed issues under the 9.4 version selector:
Fixed issues for Splunk Enterprise 9.4.0, 9.4.1, and 9.4.2 are shown under the 9.4 version selector.
