Monitor IIS Application Pools
You can monitor the health of IIS application pools for the instrumented .NET nodes in a tier. You can view the information by application pool, machine, and process IDs.
This view enables you to visualize key performance indicators for your infrastructure, such as node health and last CLR restart time.
To view the IIS application pools:
  1. In the left navigation pane, click Tiers & Nodes > Tier dashboard > Nodes tab.
  2. In the Show Data dropdown, select IIS App > Pools.
    Note: If a machine or application pool name is not available for a .NET node, the .NET Agent creates the "Unknown App Pool" / "Unknown Machine" grouping.
