Default IIS Metrics for .NET
You must install IIS on the machine to view the metrics for IIS, ASP.NET, and ASP.NET applications. The .NET Machine Agent uses Microsoft Windows Performance Counters to gather IIS metrics. In the Controller, you can view preconfigured metrics for IIS in the Metric Browser.
IIS Metrics
From the Metric Browser:
- To view the IIS metrics for a tier, expand .
- To View the IIS metrics for a node, expand .
Splunk AppDynamics reports each metric for the entire tier, each individual application pool, and each individual node as follows:
- : combined for all IIS processes in all Application Pools for this tier
- : combined for all processes in this specific Application Pool
- : metrics for the specific node
ASP.NET Metrics
To view the ASP.NET metrics in the Metric Browser, expand .
Splunk AppDynamics reports these ASP.NET metrics:
- Application Restarts
- Applications Running
- Requests Disconnected
- Requests Queued
- Requests Rejected
- Request Wait Time
- Worker Process Restarts
ASP.NET Application Metrics
To view the ASP.NET Application metrics in the Metric Browser, expand .
Splunk AppDynamics reports these ASP.NET Application metrics:
- Anonymous Requests
- Anonymous Requests/sec
- Cache Total Entries
- Cache Total Hit Ratio
- Cache Total Turnover Rate
- Cache API Entries
- Cache API Hit Ratio
- Cache API Turnover Rate
- Errors Unhandled During Execution/sec
- Errors Total/sec
- Errors During Preprocessing
- Errors During Compilation
- Errors During Execution
- Errors Total
- Errors Total/sec
- Output Cache Entries
- Output Cache Hit Ratio
- Output Cache Turnover Rate
- Pipeline Instance Count
- Requests Executing
- Requests Failed
- Requests In Application Queue
- Requests Not Found
- Requests Not Authorized
- Requests Succeeded
- Requests Timed Out
- Requests Total
- Requests/sec
- Session State Server Connections Total
- Session SQL Server Connections Total
- Sessions Active
- Sessions Abandoned
- Sessions Timed Out
- Sessions Total
- Transactions Aborted
- Transactions Committed
- Transactions Pending
- Transactions Total
- Transactions/sec
