Controller Compatibility with Operating Systems and Components
The following tables list the controller compatibility with various operating systems and other on-prem components for new installation and upgrades. For agent compatibility with the controller, see Agent and Controller Tenant Compatibility.
Operating Systems Support
These operating systems support the Splunk AppDynamics platform:
| Linux (64 bit) | Microsoft Windows (64 bit) |
*RHEL7.9 does not support the installation of Private Synthetic Agent.
Effective with the release of Splunk AppDynamics version 25.1.0, RHEL 7 will no longer be a supported operating system for Splunk AppDynamics. See End of Support Notice: RHEL 7.
You can use the following file systems for machines that run Linux:
- ZFS
- EXT4
- XFS
AppDynamics Compatibility Checker
Choose the required component and expand the versions to view the compatible component versions:
- Controller
25.7
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4, 24.7, 25.1, 25.7 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1, 25.4, 25.7 Synthetic Server 24.3, 25.1, 25.4, 25.7 25.4
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4, 24.7, 25.1 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1, 25.4 Synthetic Server 24.3, 25.1, 25.4 25.1
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4, 24.7, 25.1 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1 Synthetic Server 24.3, 25.1 24.10
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4, 24.7 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1 Synthetic Server 24.3 24.7
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4, 24.7 EUM Server 23.7, 23.8, 24.3, 24.4 Synthetic Server 24.3 24.4
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4 EUM Server 23.7, 23.8, 24.3, 24.4 Synthetic Server 24.3 - Events Service
25.7
Component Compatible Versions Controller 24.4, 24.7, 25.1 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1 Synthetic Server 24.3, 25.1, 25.4, 25.7 25.4
Component Compatible Versions Controller 24.4, 24.7, 25.1, 25.4 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1, 25.4 Synthetic Server 24.3, 25.1, 25.4, 25.7 25.1
Component Compatible Versions Controller 24.4, 24.7, 25.1 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1 Synthetic Server 24.3, 25.1 24.7
Component Compatible Versions Controller 24.4, 24.7 EUM Server 23.7, 23.8, 24.3, 24.4 Synthetic Server 24.3 24.4
Component Compatible Versions Controller 24.4 EUM Server 23.7, 23.8, 24.3, 24.4 Synthetic Server 24.3 - EUM Server
25.7
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.4, 25.7 Events Service 24.4, 24.7, 25.1, 25.7 Synthetic Server 24.3, 25.1, 25.4, 25.7 25.4
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1, 25.4 Events Service 24.4, 24.7 Synthetic Server 24.3, 25.1, 25.4 25.1
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1 Events Service 24.4, 24.7 Synthetic Server 24.3, 25.1 24.10
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1 Events Service 24.4, 24.7 Synthetic Server 24.3 24.4
Component Compatible Versions Controller 24.4, 24.7, 24.10 Events Service 24.4 Synthetic Server 24.3 - Synthetic Server
25.7
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1, 25.4, 25.7 Events Service 24.4, 25.1, 25.4, 24.7, 25.7 EUM Server 24.3, 24.4, 24.10, 25.1, 25.4, 25.7 25.4
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1, 25.4 Events Service 24.4, 24.7, 25.1, 25.4 EUM Server 24.3, 24.4, 24.10, 25.1, 25.4 25.1
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1 Events Service 24.4, 24.7,25.1 EUM Server 24.3, 24.4, 24.10, 25.1
To upgrade the Controller from a previous version to the latest version, see Upgrade Platform Components.
