Working with OCSF-formatted data in the Splunk platform and Splunk Enterprise Security
Use add-ons and CIM mappings to support timestamping and threat detections for Cybersecurity Schema Framework (OCSF) events in the Splunk platform.
If you choose not to use the OCSF-CIM Add-On for Splunk, then you must manually configure timestamp extractions in the Splunk platform and detections in Splunk Enterprise Security.
- To configure the Splunk platform deployment to extract event timestamps for the incoming OCSF-formatted data, do one of the following:
Install and configure the OCSF-CIM Add-On for Splunk. When configuring the add-on, you must select the source types that are prefixed by
ocsf:
and correspond to your incoming data. For example, if you are ingesting and convertingcisco:asa
data to OCSF format, then select theocsf:cisco:asa
source type when configuring the add-on. For more information, see the OCSF-CIM Add-On for Splunk documentation.Note: The OCSF-CIM Add-On for Splunk is not a Splunk-supported application. It is provided "as is" without any warranties, maintenance and support, or service level commitments.- Add the following stanza to the props.conf file for your indexers:
[(?::){0}ocsf:*] SHOULD_LINEMERGE = False TRUNCATE = 8388608 TIME_PREFIX = "time"\s*\:\s* TIME_FORMAT = %s%6N MAX_TIMESTAMP_LOOKAHEAD = 25 KV_MODE = json category = Structured description = JSON-formatted data compliant with OCSF (Open Cybersecurity Schema Framework)
For more information, see props.conf in the Splunk Enterprise Admin Manual and Configure timestamp recognition in the Splunk Cloud Platform Getting Data In manual.
- In the Edge Processor service, create a pipeline that converts your incoming data to OCSF format and then sends it to the Splunk platform. You can choose to convert the data using the
ocsf
SPL2 command or theto_ocsf
SPL2 evaluation function.To overwrite the data in the
_raw
event field with the converted data, use theocsf
command. For more information, see Convert data in the “_raw” field to OCSF format.To specify different event fields for storing the original data and the converted data, use the
to_ocsf
function. For more information, see Convert data in a specified event field to OCSF format.
Note: In both cases, you can configure the pipeline to preserve a copy of the original data. If you did not install the OCSF-CIM Add-On for Splunk, then you must create detections in Splunk Enterprise Security to search for threats in your OCSF-formatted data. For more information, see the Detections chapter in the Administer Splunk Enterprise Security manual.
In Splunk Enterprise Security, navigate to the Mission Control page and review the analyst queue for any findings resulting from your data. For more information, see the Findings chapter in the Administer Splunk Enterprise Security manual.
