Search with incident data in Splunk Mission Control
Make sure that you're correctly using incident fields when searching data about incidents in Splunk Mission Control.
Indexed incident fields either come from the initial event sent to Splunk Mission Control from Splunk Enterprise Security (Cloud), or Splunk Mission Control adds them automatically. This table describes the fields added by Splunk Mission Control that are present in all incidents so that you can accurately interpret them. Other fields might be present based on the data sent from Splunk Enterprise Security (Cloud). To learn more about incidents, see Triage incidents using incident review in Splunk Mission Control.
| Field name | Description | When to use |
| assignee | Uniquely identifies the user assigned to the incident | To determine who currently is assigned to work an incident or who was assigned to it in the past |
| create_time | The time that an incident was created in Splunk Mission Control | To determine the time an incident was created |
| description | The description of the incident | To understand more information about the incident |
| disposition | The classification of the incident, such as True Positive or False Positive | To determine how the incident is classified |
| id | Uniquely identifies an incident in Splunk Mission Control | To search for a specific incident |
| incident_type | Uniquely identifies the incident type assigned to the incident | To determine what incident type is assigned to the incident or complete incident type specific metrics |
| name | The name of the incident | To understand what types of incidents are common in your environment |
| sensitivity | The sensitivity of the incident is based on the US-CERT Traffic Light Protocol (TLP). Search "Traffic Light Protocol (TLP) Definitions and Usage" on the Department of Homeland Security website for more information. If no value existed in the original incident, a default value is used. | To differentiate metrics for different sensitivity levels |
| sourcetype | The source of the incident | To determine the source of the incident |
| status_name | The status of the incident (if no status is specified when the event was sent, a default value is used) | To determine how many incidents are in which status of the investigation |
| summary | The summary of incident data | To see an overview of an incident including various fields |
| update_time | The time that changes were last made to the incident, such as by modifying the status or severity | To understand how active an incident investigation is |
| urgency | The urgency of the incident | To determine when the incident needs to be investigated |
Example searches for incidents in Splunk Mission Control
Use these example searches to learn more about incidents in Splunk Mission Control.
Determine incident metrics
To calculate metrics based on the most recent state of an incident, use the following search.
| `mc_incidents` | eventstats count as total_incidents_count
Determine the number of users assigned to an incident
To learn how many different users were assigned to an incident while it was being investigated, use the following search.
|`mc_incidents` | stats count by assignee
Determine the number of incidents for each incident type
To learn how many incidents each incident type has associated with it, use the following search.
|`mc_incidents` | stats count by incident_type
Determine the average duration of open incidents for each incident type
To find the average time that each incident type remains open before it's resolved, use the following search.
|`mc_incidents`
| search status_name="Resolved"
| eval duration=update_time-create_time
| stats avg(duration) by incident_type
Determine which incidents have specific summary data
To find incidents with a specific value for a specific field, such as 8.21.146.47 for dest, use the following search.
|`mc_incidents` | search summary.dest="8.21.146.47"
Number of incidents open after the SLA time passed
To see the number of incidents that are still open after the SLA time period elapsed, use the following example search. The sla field refers to the time when this incident passes the SLA, in seconds. For example, if an incident is created at 9 am, and the SLA expires in 1 hour, the sla key has the epoch time of 10 am.
| `mc_incidents` | where status_name != "Closed" | eval current_time = now() | spath input=sla output=sla_epoch path=sla| eval sla_diff =sla_epoch - current_time | where sla_diff < 0 | table sla_diff, sla_epoch, id, current_time
