Instrument iOS applications for Splunk RUM
Learn how to instrument your iOS applications for Splunk Observability Cloud real user monitoring / RUM and what data you can collect.
Instrument your iOS applications to get Real User Monitoring (RUM) data into Splunk Observability Cloud. With Splunk RUM for Mobile, you can gain insight about the performance and health of your mobile apps.
Get started with Splunk RUM for Mobile
To generate all the basic installation commands for your environment and application, use the iOS Instrumentation guided setup. To access the iOS Instrumentation guided setup, follow these steps:
Log in to Splunk Observability Cloud.
Open the iOS Instrumentation guided setup . Optionally, you can navigate to the guided setup on your own:
In the navigation menu, select Data Management.
Go to the Available integrations tab, or select Add Integration in the Deployed integrations tab.
In the integration filter menu, select By Use Case.
Select the Monitor user experience use case.
Select the iOS Instrumentation tile to open the iOS Instrumentation guided setup.
For detailed installation instructions and requirements, see Install the iOS RUM library for Splunk RUM.
See also
Learn about the Splunk iOS RUM data model. See iOS RUM data model.
