Related org metrics for metrics pipeline management
Splunk Infrastructure Monitoring provides some metrics to help you measure your usage of metrics pipeline management and how it affects your subscription. For more information on how to view these metrics, see Access organization metrics.
Data point ingestion metrics
Metric name
Description
sf.org.datapointsTotalCount
Total number of data points Infrastructure Monitoring ingested in your organization
sf.org.datapointsTotalCountByToken
One value per token, number of data points Infrastructure Monitoring ingested
sf.org.grossDatapointsReceived
Reserved for Infrastructure Monitoring internal use only.
sf.org.grossDatapointsReceivedByToken
Data point aggregation metrics
Metric name
Description
sf.org.numReceivedDatapointsAggregated
Number of data points metrics pipeline management aggregated based on configured rules in your organization
sf.org.numReceivedDatapointsAggregatedByToken
One value per token, number of data points metrics pipeline management aggregated based on configured rules
Data point dropping metrics
Metric name
Description
sf.org.numDatapointsDroppedMetricRuleset
Number of data points metrics pipeline management dropped based on configured rules in your organization
sf.org.numDatapointsDroppedMetricRulesetByToken
One value per token, number of data points metrics pipeline management dropped based on configured rules
sf.org.numAggregatedDatapointsDroppedThrottle
Number of data points metrics pipeline management dropped when the aggregation metrics are more than the limit configured for your organization
sf.org.numAggregatedDatapointsDroppedThrottleByToken
One value per token, number of data points metrics pipeline management dropped when the aggregation metrics are more than the limit configured for your organization
sf.org.numDatapointsDroppedInTimeout
Number of data points Splunk Observability Cloud didn’t attempt to create because Splunk Observability Cloud throttled or limited your account in the previous few seconds, and creation was unlikely to succeed.
sf.org.numDatapointsDroppedInTimeoutByToken
sf.org.numDatapointsDroppedExceededQuota
Number of new data points you sent to Infrastructure Monitoring but Infrastructure Monitoring didn’t accept because your organization exceeded its subscription limit. To learn more about the process Infrastructure Monitoring uses for incoming data when you exceed subscription limits, see Infrastructure Monitoring subscription usage (DPM plans).
sf.org.numDatapointsDroppedExceededQuotaByToken
One value per token, number of new data points you sent to Infrastructure Monitoring but Infrastructure Monitoring didn’t accept because your organization exceeded its subscription limit. To learn more about the process Infrastructure Monitoring uses for incoming data when you exceed subscription limits, see Infrastructure Monitoring subscription usage (DPM plans). The sum of all the values might be less than the value of sf.org.numDatapointsDroppedExceededQuota. For more information, see Metrics for values by token.
sf.org.numDatapointsDroppedThrottle
Number of data points you sent to Infrastructure Monitoring that Infrastructure Monitoring didn’t accept because your organization significantly exceeded its DPM limit. Unlike sf.org.numDatapointsDroppedExceededQuota, this metric represents data points for both existing and new MTS. If Infrastructure Monitoring is throttling your organization, it isn’t keeping any of your data.
sf.org.numDatapointsDroppedThrottleByToken
One value per token, number of data points you sent to Infrastructure Monitoring that Infrastructure Monitoring didn’t accept because your organization significantly exceeded its DPM limit. Unlike sf.org.numDatapointsDroppedExceededQuota, this metric represents data points for both existing and new MTS. If Infrastructure Monitoring is throttling your organization, it isn’t keeping any of your data. The sum of all the values might be less than the value of sf.org.numDatapointsDroppedThrottle. For more information, see Metrics for values by token.
sf.org.numDatapointsDroppedInvalid
Number of data points dropped because they didn’t follow documented guidelines for data points. For example, the metric name was too long, the metric name included unsupported characters, or the data point contained no values.
sf.org.numDatapointsDroppedInvalidByToken
Number of data points dropped for a specific access token because they didn’t follow documented guidelines for data points. For example, the metric name was too long, the metric name included unsupported characters, or the data point contained no values.
sf.org.numDatapointsDroppedBatchSize
Number of data points dropped because a single request contained more than 100,000 data points. In this scenario, Splunk Observability Cloud drops data points because it perceives sending more than 100,000 data points in a single request as excessive.
sf.org.numDatapointsDroppedBatchSizeByToken
One value per token, number of data points dropped because a single request contained more than 100,000 data points. In this scenario, Splunk Observability Cloud drops data points because it perceives sending more than 100,000 data points in a single request as excessive.
Data point retention metrics
Metric name
Description
sf.org.numDatapointsReceived
One value per metric type, each representing the number of data points that Infrastructure Monitoring received and processed. The sum of the values represents the total number of data points you sent to Infrastructure Monitoring, minus any data points that weren’t accepted because you exceeded a limit. You can have up to three metric time series (MTS) for this metric.
sf.org.numDatapointsReceivedByToken
One value per metric type per token, each representing the number of data points Infrastructure Monitoring received and processed. The sum of values for a token is the total number of data points you sent to Infrastructure Monitoring, minus the number of data points that Infrastructure Monitoring didn’t accept because you exceeded a limit. You can have up to three MTS for this metric.
Metric rulesets org metrics
Metric name
Description
sf.org.metricruleset.numMetricRulesets
Number of metric rulesets created in your organization
sf.org.metricruleset.numAggregationRules
Number of aggregations in your organization
sf.org.metricruleset.numMetricRulesetsWithDataDrop
Number of metric rulesets with data dropping enabled in your organization
