Monitor services and hosts in Splunk Infrastructure Monitoring
Learn about navigators in Splunk Infrastructure Monitoring
See the following pages for more information about monitoring public cloud, container, or host integrations:
Public clouds
Containers
My Data Center
Scenarios for navigators
Splunk Observability Cloud also provides metrics and other data for the following host and application monitors.
Displayed data: Traffic considerations
Information is displayed only if data is streamed in. If there’s no data coming in from a stream for more than 3 hours, that stream stops being counted in Splunk Observability Cloud.
Kubernetes monitoring holds tiles in a deactivated state until it goes inactive, which happens 25 hours after the last data point is received.
Some metrics, like those related to CPU utilization, are always reported. Splunk Observability Cloud uses these metrics on the Navigator summary page.
A few metrics are not sent continuously. For example, metrics related to the number of errors are only sent when errors happen.
Don’t try to get a list of entities using one of the few metrics not sent continuously, because entities with no errors might be hidden.
Counts are sensitive to the time range, the calculated resolution of the job that runs, and the frequency of the data that is coming in.
A typical cloud integration reports a new data point every 5 minutes.
As the job is running, reporting instances that are turned off drop off after the time range that they are part of passes.
Navigator considerations
Navigators display information when an entity is both active and sending metrics, whether they are being monitored by a cloud integration or by an agent. Navigators are sensitive to the time range selected, and queries with a broader time range take longer.
The Infrastructure Overview page only shows the latest data point, regardless of the selected time range.
You can see historical numbers in the purple graph, but the number displayed will be the latest value.
Even if you select a wide time range, navigators only displays entities active in the most recent data point.
