Convert data in the “_raw” field to OCSF format
Use the ocsf SPL2 command in an Edge Processor pipeline to convert data from a raw text format to the Open Cybersecurity Schema Framework (OCSF) format.
If the data that you want to convert to OCSF format is stored in an event field called _raw, and you want to store the OCSF-formatted results in the _raw field, then use the ocsf SPL2 command in your pipeline.
ocsf command prefixes the specified source type with ocsf: and then stores the updated source type in the sourcetype field. This change ensures that your data is associated with a source type that is supported by the OCSF-CIM Add-on for Splunk and Splunk Enterprise Security._raw field from a raw text format into the OCSF format. The pipeline also prefixes the specified source type with ocsf: and then stores the updated source type in the sourcetype field.Example: Use the ocsf command to convert data
| _raw | source_device |
| <166>Oct 06 2021 12:56:34 10.160.0.10 : %ASA-6-611101: User authentication succeeded: IP address: 10.160.39.123, Uname: admin | cisco:asa |
import ocsf from /splunk.ingest.commands
$pipeline = | from $source | ocsf sourcetype=source_device include_raw=true | into $destination;
                        Parses the data from the _rawfield based on the source type indicated in thesource_devicefield.
                        Converts the data into OCSF format.
                        Includes a copy of the original data in the raw_dataattribute in the converted data.
                        Overwrites the _rawfield with the converted data.
                        Adds a sourcetypefield that contains the value from thesource_devicefield prefixed withocsf:.
| _raw | source_device | sourcetype |
|  | cisco:asa | ocsf:cisco:asa |
For more information, see the following pages:
