Splunk Mobile for Android features
Using Splunk Mobile for Android, you can get live updates and visualizations triggered by your data that you can organize, share, and respond to.
For release notes for this version, see Splunk Mobile for Android release notes.
The following table lists the features that Splunk Mobile for Android and iOS offer:
Feature Android iOS
View dashboards using Splunk Mobile
  • Receive native push notifications triggered by your Splunk data.
  • Respond to alerts.
  • View detailed visualizations that contain data about what happened during trigger time.
Yes Yes
Send alerts and dashboards to Splunk Mobile users
  • View and interact with dashboards from Splunk Enterprise and Splunk Cloud Platform.
  • View and interact with a wide variety of visualizations. See Visualization support for Connected Experiences apps in the Splunk Secure Gateway Release Notes manual for more information.
Yes Yes
View reports in Splunk Mobile
  • View, search for, and favorite reports.
  • Share reports with others from Splunk Mobile.
Yes Yes
View public Splunk instances
  • View open-sourced data about current events in dashboards created by Splunk
Yes Yes
Deploy Splunk Mobile at scale with MDM and in-app registration
  • With a compatible MDM provider, you can configure in-app device registration and securely distribute Splunk Mobile for Android to a large number of devices.
Yes Yes
Register to multiple Splunk instances
  • Get alerts and dashboards from multiple Splunk instances, such as from Splunk Enterprise, Splunk Cloud Platform, or Splunk SOAR (on-premises).
Yes Yes
Use Splunk SOAR (on-premises)
  • Register to a Splunk SOAR (on-premises) instance to run playbooks, see event details, and communicate with other Splunk SOAR (on-premises) users from your mobile device.
No Yes
To get started with Splunk Mobile for Android, use Splunk Secure Gateway on your Splunk platform instance. See Log into a Splunk platform instance from a Connected Experiences app in the Use Splunk Secure Gateway manual.
To download and use Splunk Mobile for Android, see the Download and Use Splunk Mobile for Android manual.
See Visualization support in the Splunk Secure Gateway Release Notes manual for supported and unsupported visualizations.
