[Alpha] Instrument Flutter applications for Splunk RUM
Learn how to instrument your Flutter applications for Splunk RUM and what data you can collect.
Instrument your Flutter applications to get Splunk RUM data into Splunk Observability Cloud and gain insight into the performance and health of your Flutter applications.
Get started
To generate all the basic installation commands for your environment and application, use the Flutter guided setup. To access the Flutter guided setup, follow these steps:
Log in to Splunk Observability Cloud.
Open the Flutter guided setup:
In the navigation menu, select Data Management.
Go to the Available integrations tab, or select Add Integration in the Deployed integrations tab.
In the integration filter menu, select By Use Case.
Select the Monitor user experience use case.
Select the Flutter Instrumentation tile to open the Flutter guided setup.
For detailed installation instructions and requirements, see [Alpha] Install the Splunk RUM Flutter agent.
