Types of forwarder data
Forwarders can transmit three types of data:
  • Raw
  • Unparsed
  • Parsed
The type of data a forwarder can send depends on the type of forwarder it is, as well as how you configure it. Universal forwarders and light forwarders can send raw or unparsed data. Heavy forwarders can send raw or parsed data.
With raw data, the forwarder sends the data unaltered over a TCP stream. It does not convert the data into the Splunk communications format. The forwarder collects the data and sends it on. This is particularly useful for sending data to a non-Splunk system.
With unparsed data, a universal forwarder performs minimal processing. It does not examine the data stream, but it does tag the stream with metadata to identify source, source type, and host. It also divides the data stream into 64-kilobyte blocks and performs some rudimentary timestamping on the stream that the receiving indexer can use in case the events themselves have no discernible timestamps. The universal forwarder does not identify, examine, or tag individual events except when you configure it to parse files with structure data (such as comma-separated value files.)
With parsed data, a heavy forwarder breaks the data into individual events, which it tags and then forwards to a Splunk indexer. It can also examine the events. Because the data has been parsed, the forwarder can perform conditional routing based on event data, such as field values.
The parsed and unparsed formats are both referred to as cooked data, to distinguish them from raw data. By default, forwarders send cooked data (universal forwarders send unparsed data and heavy forwarders send parsed data.) To send raw data instead, set the sendCookedData=false attribute/value pair in outputs.conf.
