Controller Compatibility with Operating Systems and Components
The following tables list the controller compatibility with various operating systems and other on-prem components for new installation and upgrades. For agent compatibility with the controller, see Agent and Controller Tenant Compatibility.
Operating Systems Support
These operating systems support the Splunk AppDynamics platform:
| Linux (64 bit) | Microsoft Windows (64 bit) |
*RHEL7.9 does not support the installation of Private Synthetic Agent.
Effective with the release of Splunk AppDynamics version 25.1.0, RHEL 7 will no longer be a supported operating system for Splunk AppDynamics. See End of Support Notice: RHEL 7.
You can use the following file systems for machines that run Linux:
- ZFS
- EXT4
- XFS
Controller Compatibility with Components
Splunk AppDynamics maintains and supports every software version for one calendar year after the next major Controller release is generally available. You have the flexibility to upgrade any component to a newer version released within the previous 12 months, without the need to synchronize these upgrades across different components. However, Splunk AppDynamics recommends adopting the most recent versions of all components on a regular basis to ensure optimal performance and feature access.
- Enterprise Console is used to administer Controller and Events Service.
- For users planning to migrate data from Elasticsearch version 2.x to 8.x using phase 1 or phase 2, ensure that you use the latest version of the Events Service.
AppDynamics Compatibility Checker
Choose the required component and expand the versions to view the compatible component versions:
- Controller
25.10
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4, 24.7, 25.1, 25.7 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1, 25.4, 25.7, 25.10 Synthetic Server 24.3, 25.1, 25.4, 25.7, 25.10 25.7
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4, 24.7, 25.1, 25.7 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1, 25.4, 25.7 Synthetic Server 24.3, 25.1, 25.4, 25.7 25.4
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4, 24.7, 25.1 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1, 25.4 Synthetic Server 24.3, 25.1, 25.4 25.1
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4, 24.7, 25.1 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1 Synthetic Server 24.3, 25.1 24.10
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4, 24.7 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1 Synthetic Server 24.3 24.7
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4, 24.7 EUM Server 23.7, 23.8, 24.3, 24.4 Synthetic Server 24.3 24.4
Component Compatible Versions Events Service 23.7, 23.10, 24.2, 24.4 EUM Server 23.7, 23.8, 24.3, 24.4 Synthetic Server 24.3 - Events Service
25.7
Component Compatible Versions Controller 24.4, 24.7, 25.1 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1 Synthetic Server 24.3, 25.1, 25.4, 25.7 25.4
Component Compatible Versions Controller 24.4, 24.7, 25.1, 25.4 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1, 25.4 Synthetic Server 24.3, 25.1, 25.4, 25.7 25.1
Component Compatible Versions Controller 24.4, 24.7, 25.1 EUM Server 23.7, 23.8, 24.3, 24.4, 24.10, 25.1 Synthetic Server 24.3, 25.1 24.7
Component Compatible Versions Controller 24.4, 24.7 EUM Server 23.7, 23.8, 24.3, 24.4 Synthetic Server 24.3 24.4
Component Compatible Versions Controller 24.4 EUM Server 23.7, 23.8, 24.3, 24.4 Synthetic Server 24.3 - EUM Server
25.10
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.4, 25.7, 25.10 Events Service 24.4, 24.7, 25.1, 25.7 Synthetic Server 24.3, 25.1, 25.4, 25.7, 25.10 25.7
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.4, 25.7 Events Service 24.4, 24.7, 25.1, 25.7 Synthetic Server 24.3, 25.1, 25.4, 25.7 25.4
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1, 25.4 Events Service 24.4, 24.7 Synthetic Server 24.3, 25.1, 25.4 25.1
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1 Events Service 24.4, 24.7 Synthetic Server 24.3, 25.1 24.10
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1 Events Service 24.4, 24.7 Synthetic Server 24.3 24.4
Component Compatible Versions Controller 24.4, 24.7, 24.10 Events Service 24.4 Synthetic Server 24.3 - Synthetic Server
25.10
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1, 25.4, 25.7, 25.10 Events Service 24.4, 25.1, 25.4, 24.7, 25.7 EUM Server 24.3, 24.4, 24.10, 25.1, 25.4, 25.7, 25.10 25.7
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1, 25.4, 25.7 Events Service 24.4, 25.1, 25.4, 24.7, 25.7 EUM Server 24.3, 24.4, 24.10, 25.1, 25.4, 25.7 25.4
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1, 25.4 Events Service 24.4, 24.7, 25.1, 25.4 EUM Server 24.3, 24.4, 24.10, 25.1, 25.4 25.1
Component Compatible Versions Controller 24.4, 24.7, 24.10, 25.1 Events Service 24.4, 24.7,25.1 EUM Server 24.3, 24.4, 24.10, 25.1
To upgrade the Controller from a previous version to the latest version, see Upgrade Platform Components.
