Costs for AWS monitoring
Costs for monitoring AWS with Splunk Infrastructure Monitoring.
To understand the costs derived from monitoring AWS with Splunk Observability Cloud, see:
Costs derived from Splunk Observability Cloud
Your subscription plan determines how you’ll be charged for sending AWS metrics to Splunk Observability Cloud. See more in Infrastructure Monitoring subscription usage (Host and metric plans).
In MTS-based subscription plans, all metrics are custom, and you’re therefore charged for them.
In host-based subscription plans, most AWS metrics are categorized as bundled, and are part of your plan.
CWAgent
Glue
MediaLive
System/Linux
WAF
For a complete list of Splunk Observability Cloud metrics, see Metric categories.
Costs derived from AWS
You can send AWS data to Splunk Observability Cloud with one of two methods, which have different associated costs:
Streaming data with Metric Streams.
Polling CloudWatch APIs:
First, the list of metrics is retrieved with
ListMetrics. -
Next, data points are fetched with
GetMetricData. Note that theGetMetricStatisticsAPI is deprecated, see more in GetMetricStatistics API deprecation notice.
Learn more at Connect AWS to Splunk Observability Cloud.
AWS pricing
AWS pricing is based on the amount of requested metrics, not the number of requests. Therefore the cost of obtaining Cloudwatch metrics for a service is based on three factors: frequency of pulling data, number of metrics for a given service, and number of cloud resources.
Generally speaking, Metric Streams costs the same as polling if the integration is synced every 5 minutes, and is cheaper (up to 5 times) when synced every minute.
However, when using Metric Stream you can’t control costs, while you can configure the polling frequency of the APIs. See how to limit the metrics to collect, the resources, or the collection frequently.
Example: Cost scenarios using polling APIs
Let’s imagine a user with the following configuration:
100,000 SQS queues
9 available CloudWatch metrics per queue
First, you need to retrieve your list of metrics using the ListMetrics API at a cost of USD 0.01 per 1,000 API calls:
Scenario |
Number of API calls per day |
Cost/day |
Metrics are listed every 15 minutes, and a list contains up to 500 items |
1440 (number of minutes in a day)/15 (pull interval) * 100k / 500 (items) = 19200 |
USD 0.192 |
Next, you retrieve the data using the GetMetricData API at a cost of USD 0.01 per 1,000 metrics requested:
Scenario |
Number of requested metrics per day |
Cost/day |
The user wants to retrieve all metrics every 1 minute |
1440 (number of minutes in a day) * 9 (number of metrics) * 100k (number of SQS resources) = 1.296B |
USD 12,960 |
The user wants to retrieve all metrics every 5 minutes |
1440 (number of minutes in a day)/5 (pull interval) * 9 (number of metrics) * 100k (number of SQS resources) = 259.2M |
USD 2,592 |
The user wants to retrieve ONLY 4 metrics for a 1,000 queues (because they’re the production instances) every 10 minutes |
1440 (number of minutes in a day)/10 (pull interval) * 4 (number of metrics) * 1000 (number of SQS resources) = 576k |
USD 5.76 |
