Create custom lists for use in Splunk SOAR (Cloud) playbook comparisons
A custom list is a collection of values that you can use in a playbook, such as a list of banned countries, or blocked or allowed IP addresses. Custom lists are used to save information in a visual format that can be used to make decisions or track information about playbooks. In your Filter and Decision blocks, compare parameters against all the values in a custom list, rather than having to configure each comparison in the playbook.
See Example of using a custom list in a filter for an example of how to use a custom list in a playbook.
Create a custom list in Splunk SOAR (Cloud)
Custom lists have a size limit of 2GB.
Perform the following steps to create a custom list in Splunk SOAR (Cloud):
  1. From the Home menu, select Playbooks.
  2. Select the Custom Lists tab.
  3. Click + List to create a new list.
  4. Enter a name for the list.
  5. Enter or paste the list values in the table using one value per cell. For example, you can create a list of banned countries, or blocked or allowed IP addresses. Right-click in a cell to add or remove rows and columns.
  6. Click Save.
Import a custom list to Splunk SOAR (Cloud) using a CSV file
Imported custom list files have a size limit of 1MB.
Perform the following tasks to import a CSV file to be used as a custom list.
  3. Click the Import Custom List CSV icon (The Import Custom List CSV icon) to import a custom list as a CSV file.
  5. Drag and drop your CSV file to the window, or click the window to locate the CSV file on your file system.
  6. Click Upload.
