Build a Monitoring Extension Using Java
You can create Java monitoring extensions that enable the Machine Agent and Server Visibility to collect custom metrics, which you define and provide, and report them to the Controller. This is an alternative to adding monitoring extensions using scripts.
When you capture custom metrics with a monitoring extension, they are supported by the same Splunk AppDynamics services that you receive for the standard metrics captured with the Splunk AppDynamics application and Machine Agents. These services include automatic baselining, anomaly detection, display in the Metric Browser, availability for display on custom dashboards, and availability for use in policies to trigger alerts and other actions.
This page describes how to create a monitoring extension in Java.
To the Agent, a monitoring extension is a task that runs on a fixed schedule and collects metrics.
Before You Begin
Before creating your own extension from scratch, review the extensions on theSplunk AppDynamics community. See GitHub for a free download of the extensions
New extensions are constantly being added. It is possible that someone has already created what you need, or something close enough, that you can download it and use it after making a few modifications.
Create a Monitoring Extension in Java
To create a monitoring extension in Java:
Create the Monitoring Extension Class
Create a monitoring extension class by extending the AManagedMonitor com.singularity.ee.agent.systemagent.api MachineAgent.jar
The monitoring extension class performs these tasks:
- Populates a hash map with the values of the metrics that you want to add to Splunk AppDynamics. You obtain these metrics based on your environment and the source from which you derive your custom metrics.
- Defines the type of metrics to collect using the
MetricWriterclass. See Metric Processing Qualifier. - Uploads the metrics to the Controller using the
execute()method of theAManagedMonitorclass.
See Extension_Class_Source.txt for example source code.
Metric Path
All custom metrics processed by the Machine Agent and Server Visibility appear in the Metric Browser > Application Infrastructure Performance. Use the "I" character to specify the path from Application Infrastructure Performance to the custom metric. If the metrics apply to a specific tier, use the metric path for the tier, with "Component" followed by a colon ":" and the tier name or tier ID.
For example to associate a metric with tier AccountService, you would specify the metric path as: Server|Component:AccountService|Custom Metrics|Path|
The metric would then appear under the tree in the Metric Browser:
You can insert a custom metric next to an existing type of metric. For example, the following declaration causes the custom metric named pool usage to appear next to the JMX metrics: name="Server|Component:<tier-name>|JMX|Pool|First|pool usage",value=10
You can then use the metric in health rules similar to other types of JMX metrics.
Metric Names
Metric names must be unique within the same metric path but need not be unique for the entire metric hierarchy.
We recommend that you use short metric names so that they are visible when they are displayed in the Metric Browser.
Prepend the metric path to the metric name when you upload the metrics to the Controller.
aggregator="aggregator type" METRIC_AGGREGATION_TYPE_AVERAGE METRIC_AGGREGATION_TYPE_SUM METRIC_AGGREGATION_TYPE_OBSERVATION METRIC_TIME_ROLLUP_TYPE_AVERAGE METRIC_TIME_ROLLUP_TYPE_SUM METRIC_TIME_ROLLUP_TYPE_CURRENT METRIC_CLUSTER_ROLLUP_TYPE_INDIVIDUAL METRIC_CLUSTER_ROLLUP_TYPE_COLLECTIVE
The Controller has various qualifiers for how it processes a metric regarding aggregation, time roll-up, and tier roll-up.
There are three types of metric qualifiers:
- Aggregator qualifier
- Time roll-up qualifier
- Cluster roll-up qualifier
You specify these options with the enumerated types provided by the MetricWriter class.
Aggregation Qualifier
Theaggregatorqualifier specifies how the Machine Agent aggregates the values reported during a one-minute period.
Specify the aggregation qualifier as
This value is an enumerated type. Valid values are:
| Aggregator Type | Description |
METRIC_AGGREGATION_TYPE_AVERAGE |
Default. Average of all reported values in that minute. |
METRIC_AGGREGATION_TYPE_SUM |
Sum of all reported values in that minute, causes the metric to behave like a counter. |
METRIC_AGGREGATION_TYPE_OBSERVATION |
Last reported value in the minute. If no value is reported in that minute, the last reported value is used. |
Time Roll-Up
Thetime-rollupqualifier specifies how the Controller rolls up the values when it converts from one-minute granularity tables to 10-minute granularity tables, and 60-minute granularity tables over time.
| Roll-Up Strategy | Description |
METRIC_TIME_ROLLUP_TYPE_AVERAGE |
Average of all one-minute data points when adding it to the 10-minute or 60-minute granularity table. |
METRIC_TIME_ROLLUP_TYPE_SUM |
Sum of all one-minute data points when adding it to the 10-minute or 60-minute granularity table. |
METRIC_TIME_ROLLUP_TYPE_CURRENT |
Last reported one-minute data point in that 10-minute or 60-minute interval. |
Cluster Roll-Up
Thecluster-rollupqualifier specifies how the Controller aggregates metric values in a tier.
| Roll-up Strategy | Description |
METRIC_CLUSTER_ROLLUP_TYPE_INDIVIDUAL |
Aggregates the metric value by averaging the metric values across each node in the tier. |
METRIC_CLUSTER_ROLLUP_TYPE_COLLECTIVE |
Aggregates the metric value by adding up the metric values for all the nodes in the tier. |
For example, if a tier has two nodes, Node A and Node B, and Node A has three errors per minute and Node B has seven errors per minute, the INDIVIDUAL qualifier reports a value of five errors per minute and COLLECTIVE qualifier reports ten errors per minute. INDIVIDUAL is appropriate for metrics such as % CPU Busy where you want the value for each node. COLLECTIVE is appropriate for metrics such as Number of Calls where you want a value for the entire tier.
Sample Monitoring Extension Class
The NGinXMonitor
Active Connections:number of active connectionsAccepts:number of accepted requestsHandled:number of handled requestsRequests:total number of requestsReading:number of readsWriting:number of writesWaiting:number of keep-alive connections
The source for the extension class is included as an attachment.
Create monitor.xml
Create a monitor.xml <monitor>
Sample monitor.xml Files
This attached monitor.xml file configures the NGinXMonitor monitoring extension. This extension executes every 60 seconds.
This jar attached monitor.xml file configures the MysqlMonitor. This monitor executes every 60 seconds, has four required task arguments and one optional task argument and one dependent
