Instrument Android applications for Splunk RUM
Learn how to instrument your Android applications for Splunk RUM and what data you can collect.
Instrument your Android applications to get Real User Monitoring (RUM) data into Splunk Observability Cloud. With Splunk RUM for Mobile, you can gain insight about the performance and health of your mobile apps.
Get started
To generate all the basic installation commands for your environment and application, use the Android Instrumentation guided setup:
On Splunk Observability Cloud, select Data Management.
Select the Available integrations tab or select
In the integration filter menu, select By Use Case.
Select the Monitor user experience use case.
Select the Android Instrumentation tile to open the Android Instrumentation guided setup.
For help, see the workflow that corresponds to the version of the Splunk RUM Android agent you want to use:
