Reference and best practices for span tags and Troubleshooting MetricSets
Learn how to drill down to gain insights about the performance of your infrastructure or to address a specific incident using Troubleshooting MetricSets (TMS).
With Troubleshooting MetricSets (TMS), you can drill down to gain insights about the performance of your infrastructure, or to address a specific incident.
See Default indexed span tags in APM for details about the span tags Splunk APM automatically indexes.
See Types of span tags you can index to learn about the types of span tags you can choose to index and their scope.
See Limits on indexing span tags for guidance on how to calculate the available number of Troubleshooting MetricSets in your system configuration.
See Decide which additional span tags to index to index for guidance on selecting additional span tags to index.
APM indexes and creates Troubleshooting MetricSets by default for the span tags in the following table:
Tag |
Example |
Type |
Description |
Global |
The environment where the service associated with the span runs. |
All services |
If the root span contains the |
All services |
The operation name for the root span of a service. |
All services |
The HTTP method of the span, if any. The actual span tag field name can be |
All services |
The type of service associated with the span. The actual span tag field name is |
The name of a service you specify when configuring instrumentation. |
All services |
The service you instrumented and are exporting trace data from. |
There are three types of span tags you can index:
Type |
Example |
Description |
Global |
Tenant class, application ID |
A tag with only a single value across a trace. This associates the span tag value with an entire trace. |
All services |
Version, host, status code |
A tag that exists for most or all services. This associates the span tag value with services in a trace. The value could change across services in a trace. |
Specific service(s) |
Job ID, database name |
A tag that exists for only a single service in a trace. This associates the span tag value with a single service in a trace. |
To learn how to index span tags, see Index span tags to create Troubleshooting MetricSets.
If you choose not to index any additional span tags, you can still view tags in your spans when analyzing whole traces. You can also download traces and filter or process data by span tags manually. To learn how to download a trace, see Download traces.
APM generates a Troubleshooting MetricSet for every unique set of indexed span tag values, so the number of span tags you can index depends on the number of Troubleshooting MetricSets that the span tags generate. This is also known as the cardinality contribution of indexed tags. The number of Troubleshooting MetricSets you can generate might be limited in your Splunk APM contract, so keep this limit in mind when you’re indexing span tags. For more information, see Splunk APM Pricing.
For information on the character limits for indexed span tag values, see Span and trace limits.
Determining the number of possible Troubleshooting MetricSets
To determine the total number of possible Troubleshooting MetricSets that indexing a tag will generate, multiply the number of indexed tag values for each indexed tag associated with each unique set of service, endpoint, operation, and environment values.
For example, consider two services, frontend and checkoutservice. Each service exists in two regions. The frontend service has five endpoints, and the checkoutservice has two endpoints. region and endpoint are indexed tags for each service. There are no other indexed tags in this scenario.
Multiplying the five endpoints for frontend by two, the number of unique regions, and then adding the result of multiplying the two endpoints for checkoutservice by two for the unique regions, we get a maximum of 14 possible combinations: (2 * 5) + (2 * 2) = 14. This doesn’t always mean there will be 14 Troubleshooting MetricSets. If you collect traces in a certain region or with a certain endpoint, the Troubleshooting MetricSet exists only for that region or endpoint.
The following table illustrates the sample set of possible Troubleshooting MetricSets given these two services and two indexed tags with multiple values:
Service |
Region |
Endpoint |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
11 |
12 |
13 |
14 |
To avoid running out of Troubleshooting MetricSets, consider which span tags are most worth indexing. Here are some questions you can consider to help you decide which span tags are most useful:
Are there any attributes I look at when an incident occurs?
If you’re running Kubernetes, you could index
k8s.pod.nameto view the performance of services by specific Kubernetes pods. -
Do I run multiple versions or builds of code at the same time?
You could index tags for
versionorbuild_idto break down your infrastructure according to specific versions or builds of your applications. -
Do I deploy services in multiple regions or fault domains?
It could be useful to view metrics for services by specific
regionspan tags to identify issues with resources in specific regions or zones. -
Do I monitor multiple products?
To get a better idea about how services for a particular product are running, you could use a span tag like
product_categoryto view metrics for traces for a single product type rather than viewing traces for multiple product types at the same time. -
How much cardinality do I need?
Some span tags provide a level of cardinality that might not be useful. For example, indexing
query_idcan generate Troubleshooting MetricSets for every unique query, and in most cases, there’s no reason for this level of cardinality. -
Do any of my tags represent ephemeral resources?
It’s best to avoid indexing span tags that represent ephemeral resources such as
container_id.
Once you have chosen which span tags you’d like to index, see Index span tags to create Troubleshooting MetricSets to learn how.
