Support Advisory: Transition of Java Agent DockerHub Images from Alpine to Scratch Base
Summary
Effective Java Agent 26.2.0, Splunk AppDynamics is transitioning the official JavaAgent DockerHub images from an Alpine-based image to a Scratch-based image. This change is part of an ongoing effort to enhance security by addressing vulnerabilities associated with the previous base image. The new Scratch-based image provides a significantly reduced attack surface, containing only the JavaAgent binaries and a minimal copy utility, with no shell present.
While a Scratch-based image was initially introduced in version 25.10.0, an Alpine-based version was temporarily re-released on November 14, 2025, to address compatibility issues involving Cluster Auto-Instrumentation and non-root user configurations. With the release of Cluster Agent version 26.2.0, these compatibility issues are resolved. Consequently, JavaAgent DockerHub releases 26.2.0 and later will be exclusively Scratch-based.
Key Characteristics of the Scratch Image
- Includes only the Java Agent binaries and a minimal copy (cp) utility.
- The
cpcommand transfers files as defined in/opt/appdynamics/sources.inifrom/opt/appdynamicsto the destination directory. - The base destination directory must already exist; the cp command can create necessary subdirectories but will not create the root destination directory.
- No shell or standard system utilities are included in the image.
Tag Changes and Image Selection Guidance
- Version 26.2.0 and later: The latest tag now points to Scratch-based image.
- Alpine-based images: To continue using Alpine-based image, use the latest-alpine tag or reference version 26.1.0 or earlier.
- Recommended Action: Evaluate your deployment requirements and update your image tags to ensure compatibility with your preferred base image (Scratch or Alpine).
Compatibility Matrix & Required Actions
Review the compatibility matrix below and adjust your deployments as needed to ensure a smooth transition.
| JavaAgent Image Version | Required Action |
| Alpine-based (< 26.2.0) | No action required |
| Scratch-based (≥ 26.2.0) | No action required |
| JavaAgent Image Version | App Run As | Required Action / Notes |
| Alpine-based (< 26.2.0) | Any | No action required |
| Scratch-based (≥ 26.2.0) | Root | No changes needed |
| Scratch-based (≥ 26.2.0) | Non-root (with runAsUser / runAsGroup parameters in Cluster Agent Conifg) | Mitigation required:
| Scratch-based (≥ 26.2.0) | Root | Use only -r with cp command: [ "cp", "-r", "/opt/appdynamics/.", "/opt/appdynamics-java" ] |
| Scratch-based (≥ 26.2.0) | Non-root | Mitigation required:
Next Steps
- Review your current deployment method and JavaAgent/Cluster Agent versions.
- Apply the specified mitigations when upgrading to version 26.2.0 or later in environments with non-root configurations.
- Contact your AppDynamics representative for further assistance or clarification.
For specific YAML or manifest guidance, contact AppDynamics support.
Verify shell or utility dependencies for deployments using custom scripts because these are not available in the Scratch-based image.
