Read and write permissions in Splunk Infrastructure Monitoring
Learn about read and write permissions and how the default rules work for dashboard groups, dashboards, and detectors in Splunk Infrastructure Monitoring
Read permissions for dashboard groups and dashboards
Here are the default read permissions configuration.
Component |
Permissions |
Dashboard group |
Everyone can see the dashboard group |
Dashboard |
Permissions are inherited from the dashboard group it is saved to |
To limit who can see your dashboards and dashboard groups, you can specify read permissions for the item. Use read permissions in the following situations:
Role |
Use case for read permissions |
User |
Limit read permissions on your user dashboard group |
Team member |
Specify that only other team members can view an item |
Administrator |
Specify that only specific users can view items that monitor critical or sensitive information |
Rules for setting read permissions
Read permissions work in the following way:
You can set read permissions for dashboard groups and dashboards.
By default, a new dashboard group or dashboard can be viewed by any user.
Administrators can grant and revoke read permissions for any item.
Write permissions
Here are the default write permissions configuration.
Component |
Permissions |
Dashboard group |
Everyone can make edits |
Dashboard |
Detector |
To prevent users from inadvertently making changes to one of these items, you can specify write permissions for the item. Use write permissions in the following situations:
Role |
Use case for write permissions |
User |
Limit write permissions on your user dashboard group |
Team member |
Specify that only other team members can edit an item |
Administrator |
Specify that only specific users can edit items that monitor critical or sensitive information |
Rules for setting write permissions
Write permissions work in the following way:
You can set write permissions for detectors, dashboard groups, and dashboards.
By default, a new detector, dashboard group, or dashboard can be edited by any user.
Anyone who has write permission for an item can grant or revoke all permissions for the item.
Anyone who has write permission can grant write permission to individual users or teams.
Anyone who has write permission for an item also has read permission for the same item.
Administrators can grant and revoke write permissions for any item.
If a team has write permission for an item, any user can join that team and thus gain write access to that particular item.
Administrators can add themselves to the permissions list for an item to gain write permission for it.
A user with write permissions to an item can add or remove others from the permissions for that item.
Read and write permissions management
To learn how to customize read and write permissions for dashboard groups and dashboards, see Specify who can see and edit your dashboard groups and dashboards.
To learn how to customize write permissions for detector, see View and manage permissions for detectors.
